  New Posts New Posts RSS Feed: waxing my R-Pod
Topic Closedwaxing my R-Pod
TEDDY View Drop Down
Direct Link To This Post Topic: waxing my R-Pod
    Posted: 05 Nov 2020 at 1:11pm
Just finsihed washing my R-Pod 178 - used McGuires stuff - good surfactant.  The prospect of waxing it, however, is daunting.  Does anyone know of a spray on wax/polish (or water-mix wash) that would do the trick?  It would be neat if one could apply something and then simply wipe at it with a mitt or cloth, rather then the laborious application of the McGuire's wax/polish.  I'm approaching 80 yrs old and some things just get harder!
Also- I have found it hard (using just McGuire's soap) to remove all the small gray spots that are probably mold spots.  I have had good results with Spray 'n Forget on wood and concrete - has anyone used it on their R-Pod gel coat?
Teddy
Direct Link To This Post Posted: 05 Nov 2020 at 3:56pm
Protect-All All-Surface Care is good. UPC:  728652620161
Direct Link To This Post Posted: 05 Nov 2020 at 4:11pm
Thanks - looks like it comes in spray bottles - might do the trick!
Teddy
Direct Link To This Post Posted: 05 Nov 2020 at 8:52pm
It also comes in gallon refills. UPC:  728652620109
Pod People View Drop Down
Direct Link To This Post Posted: 05 Nov 2020 at 9:22pm
we use Meguiares Ultimate Wash and Wax. It is very easy and does not require buffing.  after you have washed, simply mix the wax with the recommended water amount and wipe it on with a cloth or mitt. Rinse with water and dry with microfiber.
We';ve used it for 6 years and the pod still lokks good.
VannIt is vey much a liquid and sheet drains off.
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 05 Nov 2020 at 11:16pm
Thanks guys.  My friend who has a boat has suggested using distilled white vinegar as a wash before using a surfactant (like Meguaires) to actually wash the fiberglass - that would probably take care of the little gray spots.
I think I'll give Meguaire's Wash and Wax a try - on easily with a mitt, then rinse off - sounds about my speed!
Teddy
JR View Drop Down
Direct Link To This Post Posted: 06 Nov 2020 at 7:05am
StephenH thanks for the sku number of the gallon refill...I have been using the small spray bottles of the Protect All for a couple of years now and really like it.
Jay
179/2019
Direct Link To This Post Posted: 12 Nov 2020 at 5:11pm
Thanks for recommendation.
