  New Posts New Posts RSS Feed: New to The Forum
Topic ClosedNew to The Forum
Colt View Drop Down
Direct Link To This Post Topic: New to The Forum
    Posted: 04 Nov 2020 at 10:10pm
I like my Redarc proportional controller.
https://www.etrailer.com/Trailer-Brake-Controller/Redarc/331-EBRH-ACCV2.html
John
'16 R-Pod 180
Jsquared View Drop Down
Direct Link To This Post Posted: 04 Nov 2020 at 11:20pm
2018 RPod 179
2015 4 Runner Trail Edition Premium
For Ultimate Fly Fishing Adventures
Direct Link To This Post Posted: 05 Nov 2020 at 7:13am
Yes it does. Tekonsha is a good brand, the P2 is adequate. Easy install, may need a interconnect cable to fuse box. etrailer.com has reasonable prices.
Direct Link To This Post Posted: 05 Nov 2020 at 7:25am
Yes, the rpods have electric brakes, they must be operating for you to be legally towing in most states. I use a Tekonsha P2. There are many choices.
Modern brake controllers all use a solid state accelerometer (like what's in your smartphone) to measure how fast your're trying to stop and send a voltage signal to your trailer brakes that is higher the faster you are slowing down. So, they are called proportional controllers.
There will be two adjustments you will make on the controller once it is installed. The first sets the max voltage output so that the trailer brakes are just short of locking up the trailer wheels when you stop  using the trailer brakes only. That gives you the best stopping power in an emergency braking situation. Most of us find that when we do that setup we wind up at full 12V output from the controller and the trailer brakes still don't lock up. That's because rPod brakes are a bit on the wimpy side.
The second adjustment (Tekonsha calls it boost level) sets the voltage output relative to how fast you are slowing down. That effectively sets the balance between how much braking action you get from your tow vehicle brakes vs your trailer brakes. That is something you can adjust depending on road conditions, trailer weight relative to TV weight, and steepness of grade you are descending. With a relatively light tow vehicle you can set the "boost" higher so that the trailer brakes do more of the work, for example.
So, whichever controller you get be sure you know how to set it up and adjust it. That will also familiarize you with the manual control which you should use each time you hitch up to be sure that the trailer brakes are actually working. You can also use it if you ever start to get any trailer sway to bring the trailer back in line without touching your tow vehicle brakes which you don't ever want to do in that situation.
Direct Link To This Post Posted: 05 Nov 2020 at 9:27am
Y’all are great- thank you 😊
2018 RPod 179
Direct Link To This Post Posted: 05 Nov 2020 at 10:51am
Our F-150 has the factory brake controller, which modulates the output according to pedal pressure (and it also has an adjustment). If your tow vehicle has a factory brake controller option, I would recommend going with that.
