  New Posts New Posts RSS Feed: Pre-Tow Checklist
Topic ClosedPre-Tow Checklist
Direct Link To This Post Topic: Pre-Tow Checklist
    Posted: 14 Oct 2020 at 1:11pm
Originally posted by Pod_Geek
Originally posted by offgrid
...What did I miss? StarStarStar
Pocket doors:  Open and secured
Satellite/cable coax:  Disconnected and stored
Satellite antenna/dish/dome:  Stowed
Beer:  Finished
Thanks, good suggestions, I don't use any of those items except the beer.Tongue I'll add them.
Since this is like a pilot's pre-fight checklist I'll have to add the beer using the "8 hour bottle to throttle" rule. LOL
I also realized that I put the fridge on 12V but didn't mention turning off the propane.
Pod_Geek View Drop Down
Direct Link To This Post Posted: 14 Oct 2020 at 12:45pm
Beer:  Finished
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L
poston View Drop Down
Direct Link To This Post Posted: 14 Oct 2020 at 12:30pm
Originally posted by jato
Maybe laminate it on a wall on either the inside or outside?
Laminate and strap it upside down on your thigh, like fighter pilots.  Maybe both thighs so the font is large enough to read!
Jim
Virginia City, Nevada
2016 R-pod 180
2015 Nissan Xterra Pro-4X
Direct Link To This Post Posted: 14 Oct 2020 at 12:21pm
Most impressive OG !  Wow, I guess after camping for the past 40 years; 34 years by tent or pop-ups and the last 10 with our 177 these are done 'automatically' in our heads.  However as I age, I suppose a list similar to what you have posted will become a necessity someday.  It will then get to the point of "now where did I place that list?"  Maybe laminate it on a wall on either the inside or outside?  Hmmm.
john in idaho View Drop Down
Direct Link To This Post Posted: 14 Oct 2020 at 9:53am
Everyone should keep a copy of this handy, for when one of the kids says -" Hey , dad.  Can we borrow the trailer this weekend?  Some of the guys want to go fishing."
Direct Link To This Post Posted: 14 Oct 2020 at 7:17am
There have been a couple of requests for this, so I thought I'd start on one. I'm certain I'm missing some good stuff so feel free to add/comment. I'll try to clean it up and organize it after a few days.
Campsite:
Gear - stowed
Clean up - complete
Slide top - clear of debris
Slide area - clear
Do the following in a "sterile" environment, eg, no side conversations, distractions,  or interruptions. OK to split duties by section.
Trailer interior:
Table - stowed
Cushions - stowed
Counters - cleared
Lights - off
a/c thermostat - off
Furnace thermostat - off
water heater - off
Water pump - off
Bath faucets - off
Shower  - stowed
Bathroom door - closed
Sink faucet - off
Sink - drained
a/c water heater element - off
Windows - closed
Bath vent - closed
TV - stowed
Fridge - set to 12V
Fridge contents - stabilized and sealed
Fridge door - latched
Cabinet doors - latched
Slide - in
Hitch connection
Coupler - latched
Jack - retracted and stowed
Jack pad - stowed
Safety chains - connected
Breakaway brake cable - attached
7 way connector - latched
Weight distribution hitch - lubricated and tensioned
Sway control - lubricated and set
Tools - stowed
Trailer exterior
Shore power cable - disconnected and stowed
City water hose - disconnected and stowed
Propane cylinder - valve closed
Stabilizers - retracted
Stabilizer pads - stowed
Lights - off
Door - closed and locked
Step - retracted
Railing - stowed
Storage door - closed
Water heater door - closed and latched
Outside shower faucets - off
Shower door - closed and locked
Operational
Tow vehicle fluid levels - checked
Tire pressures - checked
Headlights - checked
Brake lights - checked
Turn signals - checked
Running lights - checked
Pets - secure
Engine start, roll forward
Oil pressure - check
Fuel level - check
Brake controller - connected
Trailer brakes - checked (rig stops with trailer brakes only)
Legos - stowed
Storage door - closed and locked
Final walkaround - complete
Family members - seated in TV
Bladders - emptied LOL
Seatbelts - secure
Navigation - ready
Dump station
Gloves - on
Hand sanitizer - ready
Sewer drain area - rinsed
Blackwater
Gate valve - closed
Cover - remove
Hose inlet - connected
Hose outlet - secured
Gate valve - open
Tank - drain
Tank - backwash as needed
Gate valve - closed
Hose - disconnect
Cover - secure
Toilet - add chemical as required
Toilet - precharge water
Gray water
Gate valve - closed
Cover - remove
Gate valve - open
Tank - drain
Tank - rinse as needed
Gate valve - closed
Hose - disconnect
Cover - secure
Hose - rinsed and stowed
Sewer drain - rinsed
Gloves - discard
Hands - sanitized
Sanitizer - stowed
Water pump - off
Faucets - off
Step - retracted
Railing - stowed
Fresh water fill
Fill source - potable
Fill hose - clean
Tank - full
Fill cover - closed
Fill hose - stowed
