  New Posts New Posts RSS Feed: converter
Topic Closedconverter
Rchuter View Drop Down
Direct Link To This Post Topic: converter
    Posted: 08 Oct 2020 at 9:04am
Thank you. Converter not charging pretty simple power going in none coming out. Need a converter
Direct Link To This Post Posted: 08 Oct 2020 at 2:03pm
Given that it is over 2 years old, check Amazon for a WFCO 8955MBA. Amazon has about the least expensive price.
It is not too hard to change out. Just be sure that the shore power is disconnected and the battery is disconnected. When you do replace it, be sure you get the battery polarity correct or it will blow the two 40A reverse polarity protection fuses in the center. Also, do be sure to download and follow the troubleshooting chart. You may find that the problem is not the converter. Why spend money if you don't have to.
Direct Link To This Post Posted: 08 Oct 2020 at 2:45pm
Yea have one on the way from Walmart.com fuses an breakers are good not much else it can be. 5 wires yes I watched the marucci video! Lol
Direct Link To This Post Posted: 08 Oct 2020 at 3:41pm
Are you sure your battery is good?
Direct Link To This Post Posted: 08 Oct 2020 at 3:45pm
Battery good as possible being a killed battery. TV recharged it a lot on way home
Direct Link To This Post Posted: 08 Oct 2020 at 5:15pm
Think you got a handle on it. The battery needs a converter, the converter doesn't need a battery. Works best in tandem.
