Page 12> |
IdahoBoy ![]() Groupie ![]() Joined: 24 Oct 2015 Location: Ketchum, Idaho Online Status: Offline Posts: 69 |
![]() Posted: 06 Oct 2020 at 1:16pm |
I am already starting to plan for next summer's four month trip to Alaska, from my home in Idaho. Since I plan to drive the Cassiar, Dempster and Denali highways I will likely need to carry at least one extra five gallon gas can. Does anyone have any insights on the best way to do this? I'm thinking I may need to install some sort of utility hauler on the back end of my 2016 171.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6456 |
The back end of the 171 is not a good place to install a carrier. Better than that would be a Stromberg-Carlson Trailer Tray. You can shop around and find the best price. That will be a whole lot better than ading weight to the rear of your RPod which could increase the probability of sway.
geewizard ![]() Senior Member ![]() Joined: 16 Apr 2017 Location: Spokane Online Status: Offline Posts: 347 |
I guess your tow vehicle is not a pickup?
It is a pickup, a Tacoma, but I don't want gas cans inside the camper shell. Alternatives?
The Trailer Tray looks good, but I already have two propane tanks and two 6 volt batteries on the tongue. I start to worry about tongue weight if I add ten gallons of gasoline.
I highly recommend against putting it on the back of the RPod. You don't have much choice then. It would have to ride in the camper shell. I want to make the same trip next year. We have a Nissan Frontier, but instead of a camper shell, I have a tonneau cover so I am in the same situation. I changed to a LiFePO4 battery mounted inside because that was about 30 lbs as opposed to the about 120 lbs for the two 6V batteries. It cost a lot, but I'm glad I did that. Now I have dual propane tanks on the tongue and I have the trailer tray with a Harbor Freight box on it. I could empty the tools out of that and put gas cans in there and I would feel good about it.
How about mounting Rotopax cans to the outside of the shell on the Taco? The less weight on the trailer itself the better.
If you're concerned about leakage from carrying fuel in the camper shell, get one of these: I've used them for years and they do not leak. You'll need a spout to go with it. That's what I'd do. No wait, I'd get two for the Cassiar trip. And a front receiver hitch for your additional spare tire. :) (I've been up and down the Cassiar, Alaska Highway, Denali Highway, etc several times). |
These are all good suggestions. I may also consider the fuel cans in a cargo basket on top of the shell. I obviously have time to think about it. I'll be backpacking frequently along the way, like in the Tombstone Range in the Yukon, so something I can secure will be a consideration.
marwayne ![]() Senior Member ![]() ![]() Joined: 25 Oct 2011 Location: Edmonton AB Can Online Status: Offline Posts: 1004 |
Page 12> |
