  New Posts New Posts RSS Feed: RPod frameing
Topic ClosedRPod frameing
Dirt Sifter View Drop Down
Direct Link To This Post Topic: RPod frameing
    Posted: 10 Oct 2020 at 11:01pm
I don't know where you live, but if close enough, schedule a tour at an Rpod plant. It helped us decide on what mods we might want to make on the unit as well as confirm this was the unit we wanted.
Greg n Deb 2020 195 HRE
Leomillan View Drop Down
Direct Link To This Post Posted: 10 Oct 2020 at 11:12am
I think they are magnetic though... aluminum frame...
Direct Link To This Post Posted: 09 Oct 2020 at 12:23pm
I have used one in past. Also the better models assist with wires.
crankster78 View Drop Down
Direct Link To This Post Posted: 09 Oct 2020 at 8:49am
Greetings:
 I think that a stud detector might work to find the frames, worth a try if you have one. they are cheap.
Crankster78  2015 r-179
Crankster 78 R-179 2015
Direct Link To This Post Posted: 05 Oct 2020 at 11:29am
Keder rail? Is that the rail that accepts the tubular part of the awning? Yes I am using that part... I can drill through that rope but need to attach another right below the bagged awning bag to secure it.
Thanx, Leo
Direct Link To This Post Posted: 01 Oct 2020 at 7:16am
Or you could drill horizontally through the keder rail to attach things, if you're not using it for something else.
Direct Link To This Post Posted: 30 Sep 2020 at 10:18pm
Thank you, I kinda heard of that, I'll have to pay better attention in the morning. Smile
Direct Link To This Post Posted: 30 Sep 2020 at 10:16pm
Thank you, assuming if the corner is only an inch I will either have to drill at an angle or catch an upright.  I'll watch that vid to see if it shows some uprights. Smile
mjlrpod View Drop Down
Direct Link To This Post Posted: 26 Sep 2020 at 10:23am
On a fall morning, if you go out and look at the side of the pod as the sun is just coming up, you can actually see the layout of the inner frame from the condensation.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 26 Sep 2020 at 7:53am
There aren’t structural drawings available, I’m sure FR considers those company confidential materials.
Here is a video showing the construction process so you can see what’s in there. The square aluminum tubing you see is 1x1 but the person I spoke to at FR was not able to provide a tube wall thickness. It’s pretty thin.
No reason to think the hood river version is any different, no one has identified any differences other than wheels, tires, lift kit that I’ve heard of.
https://m.youtube.com/watch?v=vMXneKc_fDo
