Page <1 23456 7> |
Author | |||
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6434 |
![]() Posted: 06 Oct 2020 at 9:20am |
It really isn't worth arguing about. In any case the real thing to remember is that sticker weight is not what will actually be towed once everything needed is loaded.
FR also says their trailers have the best construction in the business.
![]() I don't believe they weighed mine, because the weight on the sticker is exactly the weight listed in their brochure with the options the trailer came with. That means that the actual weight matched the predicted weight to within about 0.03%. Extremely unlikely. Maybe their scale was down the day that my trailer came off the line and their default procedure under that condition is to put the standard weight sticker on the trailer. That kind of thing is very common in industrial manufacturing.
I tried to work backward from my actual weight to the listed empty weight and couldn't do it, my trailer is heavier by about 150 lbs than I can account for. The 150 lb number (5%) is a pretty reasonable weight variation to expect on something mostly constructed out of wood and fiberglass sheeting. Either of us could be wrong, or right. We just don't have sufficient information to know. |
pedwards2932 ![]() Senior Member ![]() Joined: 21 Sep 2020 Online Status: Offline Posts: 333 |
I am going to make sure the weight is correct tomorrow. I got the specs for a 2012 Highlander online and was just using as example. Length difference is 10" Wheelbase is 4". Weifht is 650 lb difference.
Dimensions 2012 Highlander
So, you saw them weigh your trailer. I am not challenging that. Extrapolating from there to the statement that FR weighs ALL trailers is what I challenge. How could you know that? I'll stand by my statement that it is extremely unlikely that my trailer sticker represents its actual weight. |
Not sure where you are getting your numbers. My Highlander curb wt is 4600 so it weighs about 1000 lbs more than the Escape. And its 270 hp, not that I think the hp matters much. And yes I really think that the wt and wheelbase difference are significant. As is the hitch weight capacity. And so does Toyota. The comparable compact SUV from Toyota is the Rav4, 3500 lbs curb wt, 106 inch wb, comes with the same 270 hp V6 as the Highlander, Tow rating 3500 lbs. I like Toyotas but I wouldn't tow my 179 with a Rav any more than I would with an Escape. Trailer drag is much more a function of the rear shape of the trailer than the front. That's because that's where a vacuum is created unless the taper angle is very shallow, around 15-20 degrees. Most teardrops' taper is much higher that, much less an rpod. And its easy to find lots of people doing lots of dumb things on the internet. No one is trying to look for reasons for you not to tow with your Escape. We are trying to share our experiences to help keep and others on the road with you safe. Do what you want. But please as a minimum get your actual trailer, tow vehicle, and combined vehicle weights and see if you are within specs at least. You won't want the liability if you aren't and have an accident where others are involved.
Well I got lucky......found the hayes sway control unit on e-bay....brand new for $210.00. WooHoo!
From the towing instruction from Ford:
The chart
shows the maximum
trailer frontal area that
must be considered
for a vehicle/trailer
combination. Exceeding
these limitations may
significantly reduce the
performance of your
towing vehicle. Doesn't say it will void warranty. I was getting 15 to 16 mpg from Penn. to VA. and I ran between 55 and 60 most of the way. So I am not seeing a big hit on performance.
I really don't want to litigate this. Lets compare a Highlander- 109in wb Escape 105in wb Highlander 188in length Escape 178in Highlander V-6 - 243hp Escape 2.0 Turbo - 245 hp. StephenH was towing with an Escape and his accident involved high winds and ice....Do you think the 600 lb weight difference would have made a difference. Again how do you define frontal area when the r-pod is not flat which is another reason I picked it. It's front end is very similar to a teardrop. In checking the other forums on this there are a lot of people using Escapes as I am.....I am aware that it is not the best tow vehicle. I feel like you are trying to look for reasons. I appreciate the help I have gotten on the forum.
No, it doesn't include the vehicle front. And it does not mean there is no trailer it can pull, it means it can't pull an RPod. Many pop up and A-frame trailers are under 30sqft,and most real tear drops.
Page <1 23456 7> |
