  New Posts New Posts RSS Feed: Black water drain
Topic ClosedBlack water drain
Marvmcd View Drop Down
Direct Link To This Post Topic: Black water drain
    Posted: 23 Sep 2020 at 3:57pm
2019 179. When driving couple weeks ago was stopped by another motorist that sewer pipe was dragging on road. Unlike other posts, not a broken hanger but the sewer line pulled out of tank. On inspection, simlly looks like a hose clamp around the tank and 3" drain and stuffed with plumbers putty or similar. Seems a bit hoaky, and at least would think there would be a hanger at ghe tank end. Anyone else have this?
Direct Link To This Post Posted: 23 Sep 2020 at 8:14pm
Probably, but mine has never come out and I am not about to remove it to check. I hope you get it back in place and tight enough so it won't come out again.
Direct Link To This Post Posted: 23 Sep 2020 at 8:38pm
thanks for reply. Did clean up, reinsert, retighten and repack with putty, seemed to get us through weekend. Just surprised it happened at all. Was on highway, not like a dirt track. Probably will install a hanger. Curious if that (hose clamp and putty) is the way these things are.
Direct Link To This Post Posted: 23 Sep 2020 at 10:25pm
Mine has a hose clamp. I don't know about putty. If you look in my mods, you will see my homemade pipe hanger. It allows the pipe to move a bit. I think it takes some of the stress off from where it goes into the tank also. However, I am going to go out in the morning and check mine.
Sailor Pod View Drop Down
Direct Link To This Post Posted: 29 Sep 2020 at 6:59pm
The bracket holding the Black Water Pipe on my 190 failed as we were just North West of Chicago on the expressway.  It dragged on the pavement for a short bit when another driver pointed below the trailer to indicate something was wrong.  The pavement did a number on the outside of the pipe in front of the valve.  We made a temporary repair to hold the pipe up with some line I had in my trailer.  A day later I found an RV shop in North Dakota that had the parts I needed and replaced them.  I used the same bolts that held the Black Water Pipe bracket in place to secure the metal strapping I wrapped around the repaired BW pipe.  It is now tightly secured by two straps.  I urge everyone to look at their BW pipe and add some strapping or another holder.  Not fun as a road repair, and this seems to be a common R Pod problem.
Direct Link To This Post Posted: 29 Sep 2020 at 8:12pm
There are numerous augmented support solutions on this web site. This is a known common issue.
