  New Posts New Posts RSS Feed: Almost a new r-pod owner
Topic ClosedAlmost a new r-pod owner
Harry & Lizanne View Drop Down
Direct Link To This Post Topic: Almost a new r-pod owner
    Posted: 02 Oct 2020 at 9:44am
We purchased our 2019 180 and on one of our trips the shower leaked underneath. It was a significant amount of water. We unscrewed the base, dried the area up, and of course we did not use the shower for the remaining time of our trip. We had previously read about this, posted by other r-pod owners, and felt fortunate it had not happened to us. Indifferent of your weight, they don’t seem to support the shower base well and it happened to us, while under warranty. The dealer reenforced the base with 4x4. No more issues. Congratulations on your purchase, we have enjoyed ours. Smile
ash View Drop Down
Direct Link To This Post Posted: 29 Sep 2020 at 1:55pm
Hi Rick,
I got a 2021 R Pod 196 at the end of July 2020, and here is a list of items I have modified so far.
  1. Bathroom sink faucet (originally too short and close to the edge of the sink making it unusable)
  2. Sofa front panel (originally too tall and rubbing the floor every time the slide-out goes in and out)
  3. Winterizing system (the hose was originally too short and not flexible enough)
  4. Kitchen pantry shelf adjustable rubber brackets (the adjustable rubber brackets would pop out after a few trips due to the weight on the shelves)
  5. Dual 12V batteries (connected positive to positive and negative to negative) for longer reserve of 12V power
2021 R Pod 196
Direct Link To This Post Posted: 25 Sep 2020 at 9:54pm
When I purchased our RP179, I took along two 6V batteries. Don't forget to take a jumper so they can be wired in series. The dealer won't provide that. You may also want to take a wrench set in case they tell you you will need to install them yourself. You should get a credit for the battery that the dealer is not providing. That is what my dealer did.
Direct Link To This Post Posted: 25 Sep 2020 at 5:51pm
According to what I’ve read, Duracell makes Kirkland batteries, so there is a good chance that the only difference is the label.
At half the price I know which ones I’d buy...
Ricktoon View Drop Down
Direct Link To This Post Posted: 25 Sep 2020 at 11:54am
Dealer wants a premium for 6 volt deep cycle batteries so I will probably buy two from Costco or Batteries Plus and take them with me. Costco Interstate 6v golf cart batteries with 210Ah are less than $100 each. Duracell at Batteries plus are about $200 each. Any big difference other than warrenty to worry about.
Thanks Rick
Direct Link To This Post Posted: 25 Sep 2020 at 7:26am
Do reconsider getting "sealed" batteries.
There is no such thing as a fully sealed lead acid battery. All lead acid batteries create hydrogen and oxygen when charging, so they are either open or have valves that can allow excess hydrogen and oxygen to escape. If they didn't they could explode.
The valve regulated (VRLA) low maintenance batteries recombine the hydrogen and oxygen inside the battery unless the charge rate and voltage gets high enough that the pressure builds and the valve opens. The problem is that you can't add more distilled water to them if that happens. For a travel trailer where the battery is getting charged and discharged a lot and there are several charging sources, the risk of overcharge and losing water is increased. Also, the chemistry of deep discharge batteries (which you want for a trailer) is different from an automotive starter, lights, ignition (SLI) battery so they use more water and need higher charge setpoints than an SLI type.
If you really feel you won't be able to remember to check the level in a standard flooded deep cycle battery then by all means get the valve regulated type. Otherwise, get flooded golf cart deep cycle batteries and check the level every few weeks, and add distilled water as needed.  Golf cart batteries are designed for deep cycle applications and are tolerant of overcharging.   And they are significantly less expensive than the low maintenance ones. Two GC2 case size 6V golf cart batteries are the largest that can fit in the rpod rack, if you will be boon docking I recommend that configuration.
Direct Link To This Post Posted: 24 Sep 2020 at 8:42pm
Jato,
Thanks for the info. The dealer is providing two batteries. If I can get two 6 volt batteries for a reasonable cost upgrade I will. Would like sealed batteries that don't require topping up but will see.
I like the idea of replacing the mattress and will plan to do that after a few shakedown trips. We pick up the R-pod in Salt Lake City and will plan a couple nights nearby to make sure everything works well.
Made three trips to Glacier this year. Rode my bike up Going to the Sun Road on the first day it was open in June. Also hiked to Sperry Chalet for a two night stay. Did some hiking trips as well.  No Grizzlies on trips this year.
More later
Direct Link To This Post Posted: 24 Sep 2020 at 8:07pm
Welcome.
Re batteries, to summarize.
1) If you don't boondock, one 12V battery is fine
2) If you do boondock, 2 6V GC2 golf cart batteries in series if starting from scratch. If you have a brand new 12V battery, get a second identical battery and wire them in parallel. Connect the + feed to the trailer to one battery and the - to the other to keep them in better balance.
3) If you want the best, lightest weight and longest life, go with lithium, but change out your rPod battery charger for one configured for Li and get a dc/dc converter so you can charge from your tow vehicle.
Finally, if you are boondocking, consider also getting a solar module and charger, 100W or larger, and/or a small generator.
Enjoy!
Direct Link To This Post Posted: 24 Sep 2020 at 7:42pm
Congratulatons Rik on your new R-Pod!  First modification made on our 2011 177 when it had 3 sleeps on the mattress was to replace it!  It was collapsing already and was less comfortable to sleep on than when we slept on the ground in a puptent.  Replaced it with a 8" Eurotop mattress and here we are over 9 years later and that mattress is still just as firm and comfortable as the day we got it.
As Stephen H wisely stated above, battery type and flavor will depend on your camping style and needs.  For us we have a pair of 12v Interstate group size 24, deep cycle batteries that are 9.5 years old and still performing well.  Why?  Maintenance is key.  I wash the case 1 or 2x/year with baking soda and flush off with a garden hose.  Also keep and eye on the electrolyte level and fill only with distilled water.  When camping in the off season (April-May or September-October) the furnace gets used a lot.  Last year when in the Rockies in September it usually was mid 40's or so at night time.  Even with those temps we still got 6 - 7 days total out of both batteries; no solar or generator either.  Change battery with it reads 12.2v (50% S.O.C.) to the other.    During the winter months in northern Michigan both batteries are pulled out and set in an unheated garage on the concrete floor.  They are given a 2 amp trickle charge in November for 24-36 hours each and then sit in hibernation mode until the following April when the trickle charge is repeated before re-installing in May.
So . . . .where will you be going on your shakedown campout?  I suppose Glacier NP will be shut by then.  It is one of our favorite parks; we love to hike there although there have been occasions like the last time not too long ago when we were a bit concerned when we spotted a huge silver-tip grizzly about 500 yards away on a trail.
Direct Link To This Post Posted: 24 Sep 2020 at 6:18pm
The new 2021 R-pod has the new glass door feature. Will need to determine if it opens enough for the change in steps. Will post more later.
Here is a walkaround of the new model.
https://www.youtube.com/watch?v=eEsbjG2T1ik
