Dirt Sifter ![]() Senior Member ![]() ![]() Joined: 30 Dec 2018 Location: Right side OR Online Status: Offline Posts: 170 |
![]() Posted: 25 Aug 2020 at 1:28pm |
Agree with ArenaBlanca. When camping in the high desert or mountains the night temps can get into freezing range, but only for an hour or two, not enough to freeze warm water usually. Disconnecting the (city) water hose is good insurance just in case.
Greg n Deb 2020 195 HRE
'07 Tundra 5.7L., '17 Tacoma 3.5L. Both with tow packages 1 Puggle, 1 Chihuahua support staff |
It would take a lot to freeze the fresh water tank but the feed line from the tank to the pump is exposed so that would freeze about as soon as the city water line. You could enclose it in foam pipe insulation and run a little water through it a few times overnight, that would probably handle temps down into the high 20's.
If you want to be sure drain the tank, disconnect the city water, and use bottled water if you hit cold conditions.
ArenaBlanca ![]() Senior Member ![]() ![]() Joined: 07 Sep 2016 Location: Alamogordo, NM Online Status: Offline Posts: 158 |
Northern NM and southern CO have already had one night of cold weather. But I don't think you will need to get a heated hose. Most campgrounds in the area have running water until they are closed. If you suspect freezing overnight temps, you have two options.
You can fill the fresh water tank and use that. The volume is such that it probably will not freeze. The second option is to disconnect from city (campground) water for overnight. Drain the hose and reconnect in the morning. You should be okay for this time of year. You might wish to call the campgrounds you plan to saty at and ask their advice.
Enjoy Life!!
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2706 |
Yes, there are close to a million acres on fire at the moment, and the news I read this morning is that the smoke is reaching as far as Nebraska.
Buckeye ![]() Newbie ![]() ![]() Joined: 20 Jan 2019 Location: LSL, MO Online Status: Offline Posts: 37 |
Thank you. Just read an article about the fires. We live in strange times. Be well and safe.
Craig-retired teacher of the blind
Carol-retired legal admin asst Spot and Sam-the miscreant Shih-tzus "Politically incorrect with no real changes expected...” Former 2017 Rpod 180 F150 5.0 4x4 |
RoverPod ![]() Senior Member ![]() ![]() Joined: 07 Mar 2020 Location: Virginia Online Status: Offline Posts: 118 |
Yes, from the California wildfires. There are also fires in Colorado right now. https://www.instagram.com/p/CEMqvKYFFsG/?hl=en ![]() |
The wildfires in California. I don't know if there are any burning in the Yellowstone area, but the smoke from California is covering a rather large area. https://img.particlenews.com/img/id/0woXo0_0Wij3rov00?type=thumbnail_1024x576
From?
Be prepared for heavy smoke, too.
Traveling to West Yellowstone and will be there for the first week of September, then on to Glacier for the second week, and down to Colorado for the third week by way of Idaho and Utah. Any weather preparation tips or thoughts from y'all? My concern is frigid mornings/water difficulties. Is it wise to invest in a water hose with the heat tape?
Thanks in advance.
