Even though I had reinforced my black tank discharge pipe with hanger iron, the iron strap and the original brace both failed on my last trip. Fortunately the valve stayed closed and the tank was nearly empty, but the valve assembly is damaged and needs to be replaced. I was wondering if it was possible to remove the original assembly without cutting it off? I assume it is attached with PVC solvent.
If I did have to cut it off, it would be little more difficult to reach. Or I could cut the 3" drain pipe farther back and add an extension. Has anyone done this repair?
I have a 190 and the black and grey discharges are not connected.
Thanks!
