Buffalohunter
Topic: Power Light while on DC power Posted: 12 Aug 2020 at 3:44pm |
Mjlrpod...you got it right thanks mucho...I pulled the plate from the wall then did as you said. The little red light goes off and on but the tv stays the same...no effect on the channel. Then I removed the grey cable and no tv action no channel and the red light on the booster was out. So the cable for the tv runs in the overhead across the bathroom to the front bed wall area. At least I solved that problem. So now I need to replace satellite/tv switch. Any thoughts...thanks so much for the help👍👍
R-pod-2020 189
2013 Toyota Tacoma
mjlrpod
Posted: 12 Aug 2020 at 12:47pm |
Maybe on your model, the light should stay on? Can't really think of anything else.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
tcj
Posted: 12 Aug 2020 at 12:32pm |
Hey mjlrpod, that is a good suggestion, thanks. I went out and did the test. The TV gets good reception with the booster switch on but lost the picture with the switch off. So, the switch is working.
2018 R-pod 180 Hood River Edition
mjlrpod
Posted: 12 Aug 2020 at 9:07am |
Just looking at the absolutely crappy crimp job they did, and the stuff all over the circuit board, there's alot of opportunity for things to be messed up. Something is possibly disabling the switch, and keeping current supplying the booster. I would say, turn on the t.v. and get a channel that works on. Then turn off the booster button. The t.v. should lose the picture when it's off. If it keeps playing, your switch is not working for some reason.
2020 R-pod 195
I'll be rpodding
Buffalohunter
Posted: 11 Aug 2020 at 6:54pm |
Thanks for the great pictures and information. The 189 is a different animal in that the cable leaves the tv and disappears into a utility box mounted just above the set and attached to the ceiling. I do have the satellite/tv switch plate. However it is located over the bed in the forward area. The tv is aft as you first walk in the door. There is no tv in the forward bed area...nothing hooked up the that switch plate. If I push that button the light comes on and off but does not affect the tv booster box on the roof. The utility box or mystery box above the tv by the door has other connections...solar/battery monitor, switch plate for the slide/awning/porch/interior lights and the furrion radio/ speaker selection switch. It is closed off, no access plate...just a hole in the bottom where the cable and the red/yellow/white input connections for the tv. I would send a picture but I don’t know how to size it down. Fortunately I have solar panels to keep the batteries charged. So that is my situation. The booster box is always on and probably will be until I tear into this mystery box to get to...the rest of the story. Thanks for all you suggestions...maybe another 189er will read this and offer something up.
R-pod-2020 189
2013 Toyota Tacoma
tcj
Posted: 10 Aug 2020 at 9:33pm |
Originally posted by Buffalohunter
Dsbryant interesting observation as I too have the little red light on the tv booster on the roof of my pod...a 2020 189. Mjlrpod’s solution sounds so easy for your pod and I do hope it works. Maybe with the 189 they built in frustration as I have no little red light or little switch anywhere that I can find that would do the trick. All the wires from my tv run up and disappear in a ceiling mounted box of mystery. Like you say probably not drawing a whole lot of power. Still it bugs me to see the light and not be able to turn it off. Did you turn yours off...I hope you did...still worrying about it here |
Buffalo, my Rpod is a 2018 180. I have the same situation with wires disappearing into a box of mystery. I did find the push on/off button on the face plate that turns on the red light on the face plate but it does not turn off the red light on the roof antenna when in the off position.
I took the face plate off to see what's in that mystery box...see photos. The only way I could get the roof light to turn off was to disconnect the gray coax cable inside the mystery box. I connected the gray coax to the third unused coax fitting in the photo and the roof light would not turn on with the push button in the on position. I am thinking about putting a on/off switch on the outside of the mystery box to turn off the power to the face plate switch. I suspect it is the red/black pair. I'll have to do some wire tracing and disconnect the battery before I cut them to install a switch though.
Wires disappearing into the mystery box. Push switch in off position.
Push switch in the on position.
Back of face plate. Red coax is attached to "Satellite" fitting on face plate. Black and gray coaxes attached to circuit board on "TV" coax fitting.
Gray coax disconnected turns off the red light on the roof antenna.
DSBryant
Posted: 10 Aug 2020 at 8:26pm |
buffalohunter - I verified that toggling that tiny little button "Off" certainly did turn off the antenna booster on the roof. The button is integrated into a cover plate roughly the size of a standard household outlet cover. It has a bright red LED that indicates the booster is on. Right next to the bright LED is the aforementioned push button. Toggle it off, and the booster on the roof and the LED goes out. Photo might help a bit. If yours disappears into the ceiling . . . then I wouldn't have any suggestions, as I definitely am a noob to the RV thing.
DSBryant
Buffalohunter
Posted: 10 Aug 2020 at 5:58pm |
R-pod-2020 189
2013 Toyota Tacoma
DSBryant
Posted: 10 Aug 2020 at 4:18pm |
mjirpod - spot on! It's a very small pushbutton that during the initial walkthrough, the salesman probably pointed out, but with so many other things to point out . . . it got lost in the shuffle.
It probably would place a very minimal drain on my batteries, but watt the heck, I'm currently very amped up that I can turn it off and not worry about it.
Thanks
DSBryant
mjlrpod
Posted: 10 Aug 2020 at 12:53pm |
On my 195, it is on when the antennea booster is turned on. If you look behind your t.v., you will probably see a small red light. That is the booster. Push the tiny button beside it and the red light should go out. The outside roof light should now be off also.
2020 R-pod 195
I'll be rpodding
