  New Posts New Posts RSS Feed: Trailer lights plug
Topic ClosedTrailer lights plug
JR View Drop Down
Direct Link To This Post Topic: Trailer lights plug
    Posted: 10 Aug 2020 at 7:51am
In your original post you said that a lot of the black rubber was worn away and you didn't know if the medal had been effected, correct?  If that is the case are you describing the "plug" or has the wire itself on the trailer lost some of its black rubber?  If the black rubber on the wire itself has been worn down due to dragging if that is the case then that will also have to be checked and or repaired as needed.  I also would think that any reputable auto repair shop could do the work you need done.
Jay
179/2019
Direct Link To This Post Posted: 10 Aug 2020 at 6:41am
termoinsals. Never heard of 'em either. Are they some kinda fancy bath salts? LOL
EchoGale, there has to be some way for your brake controller to be adjusted to provide the the right amount of braking action from the trailer. That is generally done with a manual control and the parking lot process I referred to. You can also use the manual control to stop mild trailer sway if you were to ever experience that. I've never seen a brake controller without a manual control either. How did you get it set it up to begin with?
Podwerks, you are right that you have to be careful when wiring up a connector. But, as long as you don't get the ground connection screwed up nothing bad will happen. Its just annoying because your lights will be messed up till you get it right. I just had that happen to me on my old horse trailer, the connector was old and cracked and fell out, by the time I got home it was just bare wires. The color codes couldn't be used, its a 1980's European trailer. The multimeter can be used to get the ground connection right, after that it was trial and error.
podwerkz View Drop Down
Direct Link To This Post Posted: 09 Aug 2020 at 10:48pm
The reason I urged the OP to have the plug replaced by a 'pro' is because, if she is unfamiliar with this stuff (she is) and messes something up in the wiring (it could happen) then bad things might occur.
Its an easy fix for some of us, but for others, not so much.
And yes, I'm also curious about the brake controller with no manual settings.
Direct Link To This Post Posted: 09 Aug 2020 at 10:15pm
Originally posted by EchoGale
Lol...you guys have way too much confidence in me. I've had the multi meter for a year and a half and only recently learned used it to test voltage in my battery (I couldn't figure out how it works with all those cryptic symbols and stuff) i certainly couldn't use it to do any part of this. I've never even heard the word termoinsals; so, no, I can't get to them (it?). Believe me, I've been thrifty since before it was cool but sometimes it's worth paying someone with skills.
I do need a little more help, though, on figuring out if my brakes are working. I do not have a "manual slide" on a brake controller my brake controller is built into my computer system.
Please refresh my memory. What tow vehicle do you have? I can't imaging any trailer brake system controller, whether after market or factory installed, not having some form of manual control.
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 09 Aug 2020 at 10:02pm
Unless you have bare metal showing in the core of the plug, and that metal is visibly scraped away, the plug may still be perfectly usable.  Two tests: plug it in and see if all of the lights do what they're supposed to do, and see if it will physically stay plugged in, assuming you plug it in correctly.
Direct Link To This Post Posted: 09 Aug 2020 at 9:01pm
+1 or 2 or 3 to what the others have said. Take it to O'Reilly's or Pep Boys or almost anywhere and they can wire it up for you.
EchoGale View Drop Down
Direct Link To This Post Posted: 09 Aug 2020 at 8:57pm
Julie
Direct Link To This Post Posted: 09 Aug 2020 at 8:40pm
+1. You can get a replacement connector at Walmart in their RV section of the automotive department as well. They really are not hard to replace. Don't wait for a shop to do it. You would end up paying a whole lot more than you would if you do it yourself. Offgrid's advice about moving one wire at a time is good if you can get to the termoinsals on your original plug. If you have to cut the wire off, you can still do it, but a multimeter will be handy to test which wire is hich in the old connector so you can match the colors for your new connector.
Direct Link To This Post Posted: 09 Aug 2020 at 7:07pm
Go to an empty parking lot and use the manual slide lever on your brake controller. See if it can stop the rig without using the brake pedal.
If you can’t find anyone to fix it for you go to any auto parts store or big box hardware place, get a new 7 way trailer connector and rewire it yourself. Do one wire at a time to be sure you don’t get them crossed up. You will need a wire cutter/stripper and a screwdriver. I’ve had my connector fall out too on one of my trailers, you’re not alone. 😜
Direct Link To This Post Posted: 09 Aug 2020 at 6:19pm
Thanks...and thanks for the reminder to check everything.  How can I tell that the brakes are working?
Julie
