Page 123 5> |
EchoGale ![]() Senior Member ![]() Joined: 10 Mar 2019 Location: FL Online Status: Offline Posts: 469 |
![]() Posted: 09 Aug 2020 at 4:35pm |
Okay, so I messed up. I guess mistakes are inevitable but go ahead and laugh.
![]() Apparently I did not get the trailer lights plugged into my TV securely. when I stopped for gas I did a walk around check and found that it had come out and dragged on the highway. Much of the black rubber on one side had worn away. I couldn't tell if the metal had been affected so I made the rest of the trip home without plugging it back in. It was a nice sunny afternoon without much traffic and I was afraid of causing an electrical problem. Now I need to take it somewhere to have the plug replaced. There's no RV dealer near me (and I haven't found them helpful if they aren't servicing an RV they sold anyway). Google only turns up DYI videos and I do not want to DIM. Who should I look for to have it fixed? Will an auto repair shop do it? Is there a better idea?
Thanks in advance |
Julie
I'd look for a trailer or RV place. Not a hard job, but with it disconnected you don't have trailer brakes. The lights are another issue. Best to get it fixed.
Oh I am getting it fixed. Its just there are no trailer or RV places around. I was wondering if there were other kinds of places that might do it.
The RV places here are far away and won't look at anything for weeks.
Julie
Is there a U-Haul place you could check with? TT
FJ Cruiser |
+1, anyplace that sells or rents trailers. No to say a repair shop can't do, but not a normal business practice.
Take it to a truck shop..almost any semi-trailer repair shop should be able to fix this. You might have to buy the new 7 way RV plug at a big box store or auto parts store, then drive into a truck repair facility (not a truck stop) and smile, show them the new plug, and the damaged one on the trailer, and they should have you going in under a half hour.
What you are looking for is a guy (or gal) who will just cut the old plug off, and wire on the new plug, playing attention to the color codes. This is assuming you have plenty of cable, enough that you can cut several inches off and still reach the plug without strain when turning. Be sure to test all functions after the job is done, before you leave the lot.
Thanks...and thanks for the reminder to check everything. How can I tell that the brakes are working?
Julie
Go to an empty parking lot and use the manual slide lever on your brake controller. See if it can stop the rig without using the brake pedal.
If you can’t find anyone to fix it for you go to any auto parts store or big box hardware place, get a new 7 way trailer connector and rewire it yourself. Do one wire at a time to be sure you don’t get them crossed up. You will need a wire cutter/stripper and a screwdriver. I’ve had my connector fall out too on one of my trailers, you’re not alone. 😜 |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6438 |
+1. You can get a replacement connector at Walmart in their RV section of the automotive department as well. They really are not hard to replace. Don't wait for a shop to do it. You would end up paying a whole lot more than you would if you do it yourself. Offgrid's advice about moving one wire at a time is good if you can get to the termoinsals on your original plug. If you have to cut the wire off, you can still do it, but a multimeter will be handy to test which wire is hich in the old connector so you can match the colors for your new connector.
Lol...you guys have way too much confidence in me. I've had the multi meter for a year and a half and only recently learned used it to test voltage in my battery (I couldn't figure out how it works with all those cryptic symbols and stuff) i certainly couldn't use it to do any part of this. I've never even heard the word termoinsals; so, no, I can't get to them (it?). Believe me, I've been thrifty since before it was cool but sometimes it's worth paying someone with skills.
I do need a little more help, though, on figuring out if my brakes are working. I do not have a "manual slide" on a brake controller my brake controller is built into my computer system. |
Julie
Page 123 5> |
