tony rpod 180
Topic: Quick How To: Installing BAL Hide-A-Spare Posted: 19 Aug 2018 at 9:02am |
Wow! You are right, thanks everybody!
GMC Canyon/RPoder
voisj
Posted: 19 Aug 2018 at 11:33am |
Originally posted by tony rpod 180
We thought about that, however we decided the rack would hang too close to the ground for our comfort. |
Here is mine on the 180. It sits just in front of the axle and hangs no lower than the axle.You can see I lowered both brackets so the hood river tire would fit between the floor and the carrier. If your hitting this stuff on anything your trying pretty hard. On the 180 you also get the added benefit of supporting the floor in the pod, I have heard of these sagging on some pods.
SLOPODMODS
John&Sue,SLO,CA
Tibof
Posted: 31 Jul 2020 at 12:27pm |
So, for a HRE, which model would be best? That is, give the most mounting flexibility. The 217 or 218. This is for a 2015 HRE. Or put another way, does the 218 have to hang so low or could it be modified? I assume the mounting bracket could be cut to give a custom fit for the tire. Or does 217 give the mounting plates plenty of bolting surface with proper tire fit?
2015 Pod Hood River Edition
2012 Tacoma Crew Cab 4 Liter
Posted: 31 Jul 2020 at 6:38pm |
Originally posted by Tibof
So, for a HRE, which model would be best? That is, give the most mounting flexibility. The 217 or 218. This is for a 2015 HRE. Or put another way, does the 218 have to hang so low or could it be modified? I assume the mounting bracket could be cut to give a custom fit for the tire. Or does 217 give the mounting plates plenty of bolting surface with proper tire fit? |
The 217 is probably your best bet. The recess between frame members is only about 4", so he spare will hang down a bit. We ended up drilling at almost the very bottom of the frame in order to make enough clearance for the spare tire.
Tibof
Posted: 01 Aug 2020 at 10:39am |
Many thanks for your information.
Tibof
Posted: 02 Aug 2020 at 1:09pm |
Has anyone used or considered the BAL Retract-A-Spare?
