Page <1234 7> |
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3350 |
![]() Posted: 28 Jul 2020 at 9:20am |
Off grid, I love it ! Sweet mowing machine!
There is a place in PA Amish country that rebuilds old horse drawn implements.
Apparently the issue with mowing with horses is that with only 2 HP available its critical to keep that sickle bar mower super sharp. Like sharpening every couple of hours or so. That, being a mechanical task, would come back to me to do. And if the horses discover a snake in the field, panic and start backing, be sure to jump off the mower to the left not the right where those super sharp blades are.....
That's great! Not exactly zero-turn, but hay! Get's the job done!
You guys are giving me tractor envy. For grass I use my little Deere x300. For brush hogging I break out the BIG GUN!! ![]() ![]() |
Not gonna contemplate trying to cut 12 acres of steep, overgrown, rough pasture with a riding mower.....
I ended up passing on the 1980"s Yanmar. Very good engines but in general parts are getting hard to come by. The search continues, but that's the fun part. Once I buy something I'll have no excuse not to actually sit on it for a few days and cut the 12 acres.... My wife wants horses again, and she deals with all the living things and I deal with all the electrical and mechanical things. So, this would be a fun way for her to mow (for about 30 minutes maybe): |
Interesting discussion and I am getting in late. 20 acres here in northern Michigan and about 1 mile south of the exact 45th parallel. Being in the golf industry for many years I have seen my share of gas and diesel tractors which include Jacobsen, Toro, Ford, MF, International, Case, and most recently Kubota. Horsepower range on all these was anywhere from 35 (Jacobsen) to 65 Kubota. In all cases I coundn't really complain about any of them, they were all real workhorses and did a spectacular especially considering their age and number of hours logged. Maintenance is key to all of them. At home I mow 3.5 acres, maybe a smidge more with a 1989 Toro Groundsmaster 220, it has a 52" deck, 23 HP Continental gas engine with just under 4000 hours. It doesn't look real purdy, but it gets the job done. Very dependable and gives a professional cut to boot. Height of deck can be adjusted from 1" to 4" (with 1/2" increments in between) by removing 4 pins on the deck, takes about 1 minute to change height of cut if needed.
To paraphrase an old sage: When I go flying through the air the last thing I want strapped to my butt is a tractor. Probably applies without ROPS.
My last option for fixed wireless service providers told me no can do. No towers serving the area. So I think its either dsl (which I have operating at 3 mbps now), satellite (latency and throttling) or US Cellular fixed internet service (throttling).
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2710 |
I only need the glow plugs on the first start in the morning. After that, it starts up like a car. I can walk away from it for 4-5 hours, and turn the key and boom, it's running. I don't know what Kubota does, but it's always been an easy starter. Out here, the main impediment to fixed wireless is the terrain. If your property is large enough with enough variation in elevation, it might be possible to put up a private relay. We have done this in a number of situations. We put up a solar-powered relay at a suitable high spot, and relay the service down to the home (or whatever). Because the relay is point-to-point, this doesn't affect the throughput, but will add a few milliseconds of latency.
Here's what I've read:
A ROPS is really a roll over protection system, meaning it is a combination of a rollbar and a setbelt. Neither is much good without the other, if not worse. Together the rollbar creates a safety zone for your body and the seatbelt keeps you in that zone when the tractor goes over.
From what I read, survival rate in a rollover using both goes from around 30% to 99%. I like those odds. If you are working the tractor under low hanging trees though the sealtbelt can be dangerous because a branch can take your head off rather than just pulling you out of the tractor. So, you need to pick and choose what you do based on conditions. I think I will go for a chainsaw to fix the tree problem myself. |
Page <1234 7> |
