Cell Phone Signal Boosters |
Page <12 |
![]() ![]() ![]() ![]() Posted: 25 Jul 2020 at 9:10am |
Yah, there is a big difference between the little omni antenna and the directional one, usually 2-3 bars. Mounting the directional one is not hard, the pole just slides together and I lay it inside the trailer with the antenna attached. If you have a ladder on your new trailer you can clamp it to that. The cable stays in the outside storage compartment, one end coming up into the interior where the weboost is and the other coiled up ready to pull out and attach to the antenna. Setup is not very difficult really.
Sounds like this stuff is still in the realm of sacrificing chickens to fix my computer.
For the sake of simplicity, I was going to mount the omni-directional antenna on the upper side of the trailer above the roof line. I spoke to a someone at Wilson and they said that there must be a minimum of 2' separation between each of the 3 major components [exterior antenna, amplifier, and interior antenna]. The price difference between the RV version and putting one together from different components is about $100, making the simplicity of the kit more attractive. But I'm concerned that the antenna will not be high enough and I really don't want to mess with antenna poles or a permanent mounting that makes clearance an issue for the trailer. I think it's back to the drawing board time.
Copper bracelets work! I know cuz I saw them on a late night infomercial...
Yah, I tried that first and nada. Tossed it in the box with my magnetic fuel savers....
What? You mean the $7.99 phone boosting sticker with the zig-zag foil pattern wont work?
I'm....I'm...I'm amazed! |
LA, I have a weboost slim and a Wilson directional cellular antenna. If I actually have one bar, my experience is that my system will bring it in. If there is no signal then forget it. You will also need 50 ft of low impedance coax (I also got that from Wilson) and an adapter connector for the weboost which they can supply. I mounted my antenna on a 3 piece 21 ft extension pole for window cleaning I got on Amazon and clamp it to the flange of my slide. I rotate it slowly while my wife watches the signal strength. Takes a couple of minutes, if you know where the tower is its faster.
I leave the little antenna that comes with the weboost on the TV and use the booster in the car when not towing, I think the slim has been replaced by the drive sleek. Should work the same, but probably uses a different connector to the coax. Whole thing is going to be about $300-350. You don't need the fancy RV version, just put a phone in the weboost cradle and use it as a wifi hotspot for any other devices you have. You can make wifi calls from a second phone so no need to swap them.
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2707 |
Wilson is the standard, but YMMV whether they will help you or not. My experience out here has been extremely mixed. It helps if you know where the nearest tower is, and can use a directional antenna to pick that up. The other issue is getting enough separation from the external and internal antennas.
I was involved in a project where we installed a very high end repeater for a retreat center near here. I did not pick the system or install it. According to the tech installing it, it cost somewhere north of $15,000, and it didn't work for squat.
Has anyone had any experience using a cell phone signal booster? I am looking at the weBoost Drive 4G-X RV, but it is pretty expensive for something that may or may not work. We often camp in areas where there is often only 1 "bar" for LTE on Verizon. We need to be able to connect our computer via the phone to receive an online course my wife is taking and need adequate data transfer for streaming.
If not weBoost, any other recommendations?
Page <12 |
