Congratulations on your purchase-sounds like part of a long
term plan.
I have owned 3 tractors and give a little bit of personal
advice based on my usage-which is different from what you may need.
It sounds like you need a 4 wheel drive tractor for the steepness
you describe. There are lots of
manufacturers that offer these in the 30-40hp range. Most have dual range
transmissions (hi and low) with 3-5 gears in each range. So, low gearing is almost always available. A
tractor this size should do everything you listed. Whether you can find a good
used one is always a question.
Some tractors have 2speed PTO’s-engine speed and ground
speed. This is desirable over a single speed PTO. Also, being able to reverse
the PTO is essential if you use an auger. Otherwise, the auger can only go down
and not up. I once screwed my tractor
into the ground with the front wheels about 2’ off the ground. What a fiasco!!
Make sure the auger and/or tractor can reverse the action before you start
digging holes.
I use a 5’ scraper blade that has multiple adjustments to
grade our long gravel drive. It can
slide left to right about 2’, can be
adjusted up or down on each end and can change the vertical angle to scrape or
cut. It is more versatile and lighter
than a box blade.
I use a boom pole for moving logs before I cut them to
length. I also have an independent
hydraulic log splitter. I think this is
easier to work with than hooking one onto the tractor. Having it independent allows you to use the
tractor, move logs, etc while the splitter is still in the wood lot. Hooking up the splitter to the tractor
requires more time, effort and the tractor must have rear hydraulic connections
and a pump.
I don’t know anything about tilling or plowing-good luck
with that.
I use a bush hog that is about 1’ wider than the rear tire
width. Anything larger gets bulky and cumbersome.
Don’t know anything about front end loaders except they require
more hydraulics. A friend has one and
his wife has horses. He uses the front
end loader to move manure and hay bales.
Older tractors are relatively easy for routine maintenance .
Newer tractors have a lot of advantages, but are more complex in the wiring and
hydraulics and will cost more $$$. I have owned my 1963 Massey Ferguson 35 for
over 30 years and it has served me well. I have done all of the maintenance,
rebuilt the carb and fuel systems, repainted it and kept it stored in my barn. These old tractors are pretty much bullet
proof if you take care of them and do the maintenance. However, I also know people with newer Kubota
and John Deere’s that love them and depend on them. Sometimes the decision comes down to what’s
locally available at the time.
Good luck with your search and your new adventure
Vann
