  New Posts New Posts RSS Feed: SOC
Topic ClosedSOC
 Post Reply Post Reply Page  <1 91011
Direct Link To This Post Topic: SOC
    Posted: 20 Jul 2020 at 9:35am
Thanks Stephen,
Now I do remember seeing that unit somewhere. Probably would be a worthwhile investment. Still, I just can't figure out where my amps are going...
Direct Link To This Post Posted: 20 Jul 2020 at 9:13am
I added a battery monitor (see my mods topic linked in signature) to monitor the state of charge. It is like a gas gauge for my LiFePO4 battery. It can be programmed for PB-Acid batteries, flooded, AGM, or Gel as well. It cost a lot less than some of them and appears to work quite well. You may wish to install one for your batteries so you will have a better grasp of the actual state of charge and lessen the state of confusion.
This is the link for the monitor:  https://smile.amazon.com/gp/product/B07FGFFHC6/
Direct Link To This Post Posted: 20 Jul 2020 at 8:40am
For me, lately, this stands for State Of Confusion.
Here's the deal this time. A few sunny crazy hot days seem like a great opportunity to stress test refrigerator and solar system. Besides, I'm really trying to understand this stuff.
First: The refrigerator is doing great! Both shore power electric and propane have maintained freezer temps below 10 and fridge has not risen above 39. And that's with measuring inside and outside pod temps above 90, albeit in the shade. Freezer is about 1/3 packed with freezer packs and 1 gallon water in fridge. I am pleased. I recently replaced OEM fan with quieter fan, added small thermostat controlled exhaust fans in upper vent and had previously replaced OEM fan thermostat with a slightly lower temperature switch. All seems to be working well.
Second: I'm having a hard time understanding electron flows!
So, for the last few days (while waiting for another panel) I've been carefully monitoring solar panel output and battery voltage (see Renogy thread). I started with what I believe were fully charged 220Ah GC's only a year old. They have been continuously charged via Pod converter - one year old Progressive Dynamics PD4655V. PD had been maintaining batteries between "Normal" charge of 13.6v and "Storage" charge of 13.2v. When I began the solar tests, battery voltage reported 12.7v after 24 hour rest (turned off converter). I have carefully maintained battery fluid level.
Over the last few days the panels have flowed about 30Ah per day to the batteries. The panels are in full sun for about 1/2 day and report 14.7v absorption charge when cranking. That's reported by the PWM controller and confirmed by a meter between controller and batteries. Every morning, before the panels start charging, battery voltage reports 12.9v. Only thing running in Pod is fridge. I do have inverter, but it is switched. The pod did sit for a week or so not long ago without any charger and the batteries never went below 12.5v
MY SOC (State of Confusion) is: Where are all those amps going? Do the batteries just ignore them? Nothing feels particularly hot and no boiling. Why isn't the PWM dropping back to float charge? Seems like it it should with fully charged batteries.
I thought I understood that the PWM controller was monitoring battery condition and would pump in amps as the batteries needed them - like the PD4655V seems to act. I thought I could estimate how many Ah the batteries would take based on my consumption. I seem to have thought wrong. Do I really have to spend more money on that Trimetric Battery Monitor....Arghhhh.
What am I missing?
