Page <1 1213141516 18> |
![]() Posted: 20 Jun 2020 at 12:17pm |
Our tow vehicle is a 2012 Ford Expedition EL. It has engine braking when in the “Tow-Haul” mode . when you touch the brake pedal, the transmission sets that speed as the max level and will downshift as necessary o maintain the set speed. I just checked our owner’s manual to be sure. It says that engine braking is available in all forward gears when the transmission is in overdrive and tow/haul selected.
We use this feature Always when towing. Vann
Even though the Escape did not have a specific "Tow/Haul" mode, it did much the same when going downhill. On steep inclines, it still required some braking, but not as much as the Frontier which does not have such a feature. I usually do turn off overdrive in the mountains and downshift as needed to help keep the speed down, braking when necessary.
Yes that is a typical setup on these vehicles....but that is type of 'passive' engine braking. IF the engine is big enough and/or the load mass or weight is low enough, and the grade is shallow enough, then that is all you need to maintain a safe speed down the hill, hardly touching the service brake pedal at all. This keeps those friction brakes nice and cool, and ready when needed to make an actual stop if needed, such as when pulling off the road into a rest area or slowing to make a sharp turn, or avoiding something on the road, traffic, obstacles, fallen rocks on the road, whatever. The throttle plate closes and air flow thru the engine is restricted, which tends to retard engine RPM thru a 'vacuum effect'...sort've. Active engine braking requires extra hardware and software to actively control or restrict engine airflow into and out of the cylinders or out the exhaust stream. Since these small engines are getting even smaller, I'd like to see some kind of active engine braking, beyond the effect of simple throttle plate closure with fuel shut-off, along with forced downshifting on a downgrade. But thats just me. |
Active downshifting was what I was trying to describe with the Escape. The Frontier lacks that.
As Ford refines the Ecoboost engine line, it is likely that they, or some clever after market automotive engineer, will develop some kind of active engine braking system. But for now, being aware that there is less engine braking potential on a small displacement engine and controlling one's descent speed as much as possible is all that is available.
On my recent trip, I actively shifted down, at times even going into 1st gear. At no time did I feel that I was getting on the ragged edge of going too fast down hill. There was no one behind me most of the time so it didn't matter how slowly I went. And, when I had folks behind me, I just pulled over to let them pass. I have to say, there are some descents I'd like to avoid in the Sierra Nevada mountains, but I avoided those with the 4.7L V-8 Dakota too. The difference in engine braking, based on my experience, not qualitatively different.
I know diesels do stuff with valve timing for engine braking but they don't have throttle valves. Are there any gasoline vehicles that do more than just downshifting and pumping against closed throttle valves? I wonder if there really is any better way to do it in a gasser?
If there were, it probably would have been brought into use as it would be a good safety feature.
Maybe they'll cut a hole in the floor where you can put your foot down onto the pavement and drag your heel. Need some pretty good boots for that.
Yabba dabba doo!
