  New Posts New Posts RSS Feed: City Water Check Valve
Topic ClosedCity Water Check Valve
Colt View Drop Down
Direct Link To This Post Topic: City Water Check Valve
    Posted: 19 Jun 2020 at 3:54pm
When I hooked up to city water, my fresh water tank filled up.  FR said I had a bad check valve and needed to replace the city water inlet (?).  Where is that check valve?  I asked for a flow/valve diagram, but got nothing.  Would leaving the center water heater by-pass valve open fill the fresh water tank?
John
'16 R-Pod 180
Direct Link To This Post Posted: 19 Jun 2020 at 4:16pm
Wrong answer. The check valve for the pump is stuck. Disconnect city water and cycle the pump several times. Then check to see if that got the blockage out of the pump's check valve. This may need to be repeated. I have not had this happen, but have read this solution a number of times on this forum.
Direct Link To This Post Posted: 19 Jun 2020 at 6:31pm
I went thru about a year of this issue. The water pump check would stick and the fresh water tank would fill. I used the recycle repair method numerous times and it would correct for use on that trip. I knew I could buy a rebuild kit, but I went ahead and bought a newer model water pump and replaced my old pump. Never had a problem since. SH is right it is the fresh water pump that is the issue.
Colt View Drop Down
Direct Link To This Post Posted: 20 Jun 2020 at 10:27am
Did you replace the pump in kind, or upgrade?  To what?  Is the check valve made into the pump?  Mine is noisier than I wish it were, and right under the bed.  Did you consider installing an expansion tank to even out pressures?
John
'16 R-Pod 180
Direct Link To This Post Posted: 20 Jun 2020 at 5:21pm
The pump I put in was same configuration as original, but a newer model. I bought it from Camping World and I believe it was a Revolution. It is much quieter than original pump. The check valves are in fact internal to the pump. I never installed an expansion tank, I have nothing against them, I regulate my water input pressure, I'm ok with that. I have a 178, the pump is in the very bottom compartment under the sink in the slide. BTW the replacement pump was around 100 bucks and physically looked more dependable than the FR OEM pump.
Direct Link To This Post Posted: 20 Jun 2020 at 5:46pm
I replaced a Shurflo 4008 with a Revolution Shurflo. That was in 2017, I made a post at the time. It was on sale for 44% off, and I may have bought from Amazon.
Colt View Drop Down
Direct Link To This Post Posted: 20 Jun 2020 at 7:00pm
Thanks!  Just what I looking for.
I guess you know where Ashland City is.  You can't get away from home.
John
'16 R-Pod 180
Direct Link To This Post Posted: 20 Jun 2020 at 8:54pm
Originally posted by Colt Did you consider installing an expansion tank to even out pressures?
[/QUOTE
I shut off the pump at night so it doesn't run under our heads in the
I shut off the pump at night so it doesn't run under our heads in the 179.
An expansion tank would only lengthen the pump cycle time, it wouldn't make the pump any quieter during operation. But an expansion tank would provide pressure for a longer period with the pump off, that might be useful at night.
Direct Link To This Post Posted: 21 Jun 2020 at 8:51am
Colt,
You're not far from us. Excellent area you're in.
Direct Link To This Post Posted: 21 Jun 2020 at 11:16am
In our 179, we turned around so our heads are toward the door side. That way, the pump is under our feet, not our heads. The wardrobe wall also helps block some of the light and also some of the sound from the AC. I did not come up with the idea, but when I heard about it, tried it and it worked out well. Plus, it is easier to climb over my wife's feet and legs than if we were facing the slide-out side and I would have to go over the middle.
