  New Posts New Posts RSS Feed: Battery Drain
Topic ClosedBattery Drain
Direct Link To This Post Topic: Battery Drain
    Posted: 15 Jun 2020 at 1:25pm
The fridge lets you know what mode it is in. What is it indicating when the problem occurs? If it is in 12V mode and you're not on shore power then the batteries will run through their capacity quickly. Any other mode should be fine.
Tibof View Drop Down
Direct Link To This Post Posted: 15 Jun 2020 at 1:16pm
?  Glad to clarify whatever I can.  Podwerkz, glad to move on and not look back.  So, at this point, it's clearly not a battery problem.  If fridge is on propane and shore power plugged in, the batteries come up and stay up.  The only time 12 volt is used on fridge is in travel, but I've encouraged kids to travel on propane. In searching, I have encountered a vague reference to the converter switching to battery fridge mode if batteries are not fully charged, as was initially the case in this issue.
2015 Pod Hood River Edition
2012 Tacoma Crew Cab 4 Liter
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 14 Jun 2020 at 9:49pm
Originally posted by Tibof
The fridge was not running on battery.  As noted, it was on shore power.  Then, when on propane, all was well.  The kids used that mode out for last week and all was good.  Now to return to a more complete diagnosis in the week ahead.  As for ignoring an unhelpful post, check out the thread from the beginning.  I tried to move on politely to the genuine comments of others.  But as you can see, sometimes that does not work.
The problem is refrigerator related (converter is new PD replacement).  When on shore power, the problem occurred.  On propane, the batteries come up and stay up.  Out for a week with no issues as long was fridge is on propane.
podwerkz View Drop Down
Direct Link To This Post Posted: 14 Jun 2020 at 8:15pm
Right. Got it. While ignoring it and moving on, but not letting it drop.
Note to self: Sarcasm and humor to make a point apparently did not work here. Oh well, I will live.
(note, more sarcasm)
Direct Link To This Post Posted: 14 Jun 2020 at 7:54pm
Batteries seem to test good.  But quickly go down.  I know that could mean a large variety of issues, but I would like to hear any ideas out there.  Perhaps there's something I have not addressed.  Batteries run through an on/off switch that I'll hafta tear apart.  Otherwise I can't think of anything.  So if you have an idea, throw it my way and I'll say thanks in advance.
I know that to you, your post seems rather obvious. However, after reading all the posts, I agree that to someone not familiar with your setup and situation, it is rather vague.
"Batteries seem to test good"
Seem to? How are you testing? Are you using a voltmeter, specific gravity tester, taking them somewhere for a load test?
"I know that it could mean a large variety of issues . . . ."
Yes, that is true. What have you checked and have you been able to rule anything out?
"Batteries run through an on/off switch that I'll hafta tear apart."
Battery cut-off switches, especially the cheap ones have been known to go bad. This is definitely something to check. The one I bought is a better quality one, https://smile.amazon.com/gp/product/B005DUUL9W/ which has performed very well since I bought it in 2016.
What is the situation that makes you say they go down quickly? What battery setup do you have? Is it a single group 24 battery or dual 6V batteries connected in series? Is the converter charging the battery/batteries properly? Is this discharge while it is sitting unused? Have you taken into account things like the antenna booster (make sure it is off unless being used by you), the CO/LP detector (can't be disconnected), the radio? The refrigerator does have power going to it as does the thermostat. All these individually might not draw much power, but together, it can add up. If the trailer is sitting unplugged, these continue to drain the battery if not disconnected. Pb-Acid batteries also self-discharge.
Direct Link To This Post Posted: 14 Jun 2020 at 5:49pm
Direct Link To This Post Posted: 14 Jun 2020 at 2:20pm
You say the problem is fridge related.  In my opinion, the fridge should never be run on battery power.  It uses way too much juice and will run just about any battery down in hours.  A/C or propane is the only way to go.
Beyond that, if you don't find someone's reply helpful, speaking just for myself, I'd just as soon you ignored it.
Direct Link To This Post Posted: 14 Jun 2020 at 1:43pm
I really don't know why we have to return to this at this point, but if we must, let's reread my original post.  There is nothing vague about it, except for someone who is truly obtuse. And if it was actually not understood as an attempt to get beyond batteries, then a question would have easily sufficed, as opposed to a snotty response intended as a condescending put-down.  Meanwhile, throughout the discussion, even after I explained further, podwerkz has had nothing to offer. Aside from all that, I very much appreciate all of the other civil inquiries and insights.
Direct Link To This Post Posted: 13 Jun 2020 at 11:27pm
Originally posted by offgrid
Podwerk's facetious point was I think that you didn't give us a whole lot of information so we could help you.
Happy to help, just need a bit more to go on.
Yep...when the question is so vague that we have to ask a lot of questions... or make a lot of random guesses.
We aren't mind readers. Well, not me anyway.
Colt View Drop Down
Direct Link To This Post Posted: 13 Jun 2020 at 4:32pm
I have a battery cut-off that cures that.  In addition to the antenna booster, the radio/clock pulls power and the CO detector apparently does, too.  Your 'fridge should have an off button that completely turns it off.  Does it not?
John
'16 R-Pod 180
