  New Posts New Posts RSS Feed: CO2 Alarm
Topic ClosedCO2 Alarm
tweb View Drop Down
Direct Link To This Post Topic: CO2 Alarm
    Posted: 04 Jun 2020 at 7:10pm
Yes, will vent the Pod. Good tip
No gas or battery hook up yet, just on house power.
JR View Drop Down
Direct Link To This Post Posted: 04 Jun 2020 at 7:26pm
Might want to pull the 12v fuse and check the voltage across the contacts in the fuse panel with a multimeter.  Possibility of low voltage, just a thought and that fuse in my 2019 179 is fuse #3 which is labled LP, WH, MP, Pump (which stands for LP; LP/CO tester, WH; water heater control circuit, MP; monitor panel (tank levels) and Pump; powers the water pump)  Hope this helps
Jay
179/2019
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 05 Jun 2020 at 1:29am
Originally posted by tweb
. If it continues, it will be removed.
I was going to suggest replacing it.  They all have an expiration date, and I suppose it's possible some of them don't live as long as expected.  Anyway, they are totally unnecessary unless you have a CO problem, in which case they can save your life.  I do not recommend removing it without replacing it.
Direct Link To This Post Posted: 05 Jun 2020 at 6:48am
+1 to TT, they do go bad and have expiration dates. I haven't looked at mine in awhile.
Direct Link To This Post Posted: 05 Jun 2020 at 8:21am
+2 to TT.  Replace it if it doesn't work.
Direct Link To This Post Posted: 05 Jun 2020 at 9:48am
+3 Looks like most of these detectors have a useful life of about 5 years, which could be about right for a 2016 depending on how long the detector sat on the shelf. There's probably is a date code on it as well. Just in case it might help you can try cleaning any dust or crud out of it first.
tweb View Drop Down
Direct Link To This Post Posted: 06 Jun 2020 at 7:34pm
Thank you for all the helpful suggestions. Will start with the fuse, then go from there.
Possibly due for a new one, as I didn't realize they need to be replaced.
Learn something new everyday!
Stay safe and healthy down there is the USA
Direct Link To This Post Posted: 06 Jun 2020 at 8:23pm
Mine was out of warranty, 60 bucks at Camping World. Ordered replacement , no issues but sensor is important. Replace it.
tweb View Drop Down
Direct Link To This Post Posted: 06 Jun 2020 at 9:52pm
Thanks mcarter,
Being in Canada I'm paying double, but yes, it's going to be replaced.
