tweb
Topic: CO2 Alarm Posted: 04 Jun 2020 at 7:10pm |
Yes, will vent the Pod. Good tip No gas or battery hook up yet, just on house power.
JR
Posted: 04 Jun 2020 at 7:26pm |
Might want to pull the 12v fuse and check the voltage across the contacts in the fuse panel with a multimeter. Possibility of low voltage, just a thought and that fuse in my 2019 179 is fuse #3 which is labled LP, WH, MP, Pump (which stands for LP; LP/CO tester, WH; water heater control circuit, MP; monitor panel (tank levels) and Pump; powers the water pump) Hope this helps
Jay
179/2019
Posted: 05 Jun 2020 at 1:29am |
Originally posted by tweb
. If it continues, it will be removed. | I was going to suggest replacing it. They all have an expiration date, and I suppose it's possible some of them don't live as long as expected. Anyway, they are totally unnecessary unless you have a CO problem, in which case they can save your life. I do not recommend removing it without replacing it.
Posted: 05 Jun 2020 at 6:48am |
+1 to TT, they do go bad and have expiration dates. I haven't looked at mine in awhile.
Posted: 05 Jun 2020 at 8:21am |
+2 to TT. Replace it if it doesn't work.
Posted: 05 Jun 2020 at 9:48am |
+3 Looks like most of these detectors have a useful life of about 5 years, which could be about right for a 2016 depending on how long the detector sat on the shelf. There's probably is a date code on it as well. Just in case it might help you can try cleaning any dust or crud out of it first.
tweb
Posted: 06 Jun 2020 at 7:34pm |
Thank you for all the helpful suggestions. Will start with the fuse, then go from there. Possibly due for a new one, as I didn't realize they need to be replaced. Learn something new everyday! Stay safe and healthy down there is the USA
Posted: 06 Jun 2020 at 8:23pm |
Mine was out of warranty, 60 bucks at Camping World. Ordered replacement , no issues but sensor is important. Replace it.
tweb
Posted: 06 Jun 2020 at 9:52pm |
Thanks mcarter, Being in Canada I'm paying double, but yes, it's going to be replaced.
