AUMAN
Topic: Black Tank Gage Posted: 02 Jun 2020 at 3:37pm |
Need expert advice please. Emptied and flushed black tank on 190, but gage on bathroom wall says 3/4 full. Please advise as we are traveling across the country. Thanks, Mike
mwsjr
Pod_Geek
Posted: 02 Jun 2020 at 3:52pm |
Many reports in various fora that black-tank gauges can't be trusted because the sensor gets some crud on it and misreports. We just used our black tank in our new 195 for its intended purpose over Memorial Day and flushed it out like crazy. Now it reports 1/3 full whereas it always reported empty prior to that. Guess those anecdotes are accurate.
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L
Posted: 02 Jun 2020 at 3:57pm |
Black tank sensors never work for very long. Most folks advice on here will be to ignore it. You can open the trap in the toilet without turning the water on and look to see if its getting full. If it is, dump it. Most folks fill the gray water tank first anyway so always dump both and you should be fine. Enjoy your trip!
Posted: 02 Jun 2020 at 4:19pm |
If I wanted a truly reliable measuring device for the black and gray water tanks, I'd cut a hole in the floor and put in a port with a dip stick for each to test them.
But I don't.
Like the Zen of trailer weight and balance, the Zen of knowing when your tanks ought to be needing a dump works fine. Just keep track of how much water is disappearing from your FWT and you can probably count on it being in the gray or black tanks. Since they're each the same size as the FWT, you'll probably have a good margin of error. If you're connected to a city water, well hopefully you're also connected to a dump line.
1016
Posted: 02 Jun 2020 at 7:07pm |
1016
Posted: 02 Jun 2020 at 7:12pm |
Go to you tube and do a search on black remedies. There’s a man has a good video on how he keeps his tank gauge working. Can’t recall his video but I know he uses 5 gallons of water and x amount of dawn dish washing liquid and leaves it in there all time in between trips. He just as he enters the campground and dumps before he sets up. I full mine up completely as we pack up to leave and then dump it. 3 years no problem with it yet.
AUMAN
Posted: 02 Jun 2020 at 7:18pm |
Thanks all. Think it is working. Mike
mwsjr
Posted: 02 Jun 2020 at 10:06pm |
Originally posted by AUMAN
Thanks all. Think it is working. Mike | It's always working. The thing is you can never count on it working right.
AUMAN
Posted: 02 Jun 2020 at 11:55pm |
That is hilarious!
mwsjr
jerome
Posted: 07 Aug 2020 at 8:07pm |
Mine is never reliable as well. At a dump station, I met a guy who says he dumps a bunch of bags of ice down the toilet and just drives, and the ice corrects the sensor problem? I go out for 10-12 days, two of us and never have had it full. In appropriate places, I will get rid of some gray water and add fresh. I have quit trying to figure out the black tank gauge
2018 RPod 180
2015 Ford F150
Super Cab
3.5L Eco-Boost
