  New Posts New Posts RSS Feed: Tire woes
Topic ClosedTire woes
Direct Link To This Post Topic: Tire woes
    Posted: 29 May 2020 at 3:39pm
Check the load range on the ST tire or tires you’re getting. I would recommend load range D.
Direct Link To This Post Posted: 29 May 2020 at 4:12pm
Originally posted by Jenga Jack
I checked the"official sticker" on the side of trailer that lists all specifications for the 2014 R-Pod Forest River Edition and for tire specs it reads LT 235/75 R15. So the tires are original.
Did you mean Hood River Edition? For the 2014 model year, the Midwest edition came with 14" tires.
Unfortunately, the nearest Goodyear tire center is 4 hours away. There is a reputable tire center in town that has ST tires. They recommended ST 225/75 R15 at about $120 each for everything.
There is nothing wrong with Discount Tire if you have one near you. I got Carlisle LR-D tires from them and have been happy with them.
If the spare is in good shape, I'll replace bad one and limp along until next season. With Covid-19 we don't plan any trips longer than 50 miles one-way. Fingers crossed...
Not a good idea. You are better off replacing both tires that will be on the ground at the same time. If you can afford it, replace the spare also. Even though it may look new, it is of the same age as the others, and should also be replaced.
Jenga Jack View Drop Down
Direct Link To This Post Posted: 29 May 2020 at 6:50pm
Yikes! Yes, I meant Hood River Edition. I don't doubt anyone's research, but here's what the specs decal reads (photo attached, you may have to zoom in to read)
I've decided to replace two tires with ST that have a "D" rating, as many have suggested. I'm reminded of an old commercial with the quote something like "...you can pay me know or pay me more later..." Call it $200 piece of mind.
Thank you all for all the advice.
Stay safe, stay healthy and happy camping!
2014 R-Pod 178 aka the "Kobra Pod"
following a 2015 4Runner wherever it may wander
Direct Link To This Post Posted: 29 May 2020 at 7:55pm
I think you will be happy with that decision.
Direct Link To This Post Posted: 30 May 2020 at 8:52am
+1. Good decision.
mjlrpod View Drop Down
Direct Link To This Post Posted: 30 May 2020 at 9:11am
When you only have one axle, you kinda want to try to remove as much risk as possible. If you suffer a blowout while driving, who knows what could happen. Even if the wheel well didn't get destroyed, who wants to sit on the side of the highway for 3 hours waiting for help.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 30 May 2020 at 11:31am
+1. If you have a blowout on a single axle R-pod, about the first thing to go will be the little fender hanging out there.
James07 View Drop Down
Direct Link To This Post Posted: 13 Nov 2020 at 7:31pm
My 2015 R-pod 178 Hood River edition also has the LT 235 x 75 x R15 tires.  They are load range C and it's time to replace them.
JengaJack et al ... Was there in difference in the ride or control between the LT vs ST tires ??  Did you get the 235 tires or did you have to go to the 225 size ??
Toyanvil View Drop Down
Direct Link To This Post Posted: 13 Nov 2020 at 11:56pm
I have a 178 HRE and went with the Falken wildpeak at3w that have the same rating as the stock HRE R pod tires and I like the look.
Poddy View Drop Down
Direct Link To This Post Posted: 14 Nov 2020 at 6:30am
About your question to bringing the pod to the garage. I'd do it myself in the drive-way. Jack up one side, take the tire off, replace temporarily with your spare tire. Then take your jack to the other side, jack up and remove 2nd tire. Leave jack in place until you get back with your newly installed tires on the rims.
2011 RP172
2015 Toyota Tacoma
Newfoundland, Canada
