  New Posts New Posts RSS Feed: Jensen LED light
Jensen LED light
packsmen View Drop Down
Post Options Post Options   Quote packsmen Quote  Post ReplyReply Direct Link To This Post Topic: Jensen LED light
    Posted: 15 Jun 2022 at 5:25am
Hello, fffriedl! If I remember it right, you can find a switch at the bottom of the LED light lamp for this model. In my opinion, the Jense model of LED lights is not so good, especially the switches position if awful for me. Right now, I have replaced all lamps and bulbs around my house with smart strip lights because I find the LED strip lights more effective and cheaper. Also, I don't need to search for switches and connect more wires around my house, and also, the led strips are cheaper than the LED lamps and bulbs.
crw8sr View Drop Down
Post Options Post Options   Quote crw8sr Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2020 at 9:33am
Thanks StephenH!  Now I can stop using "Frog" tape to cover it up.
Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2020 at 7:51am
+1 to StephenH's solution. The electrical load on the Jensen is not significant enough to be an issue boondocking, and the built in dimming function works just fine.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2020 at 7:32am
On the Jensen unit, there is an easier way to turn off the light. The two arrow buttons to the left of the display adjust the brightness. The light can be turned all the way off there. I usually keep it at the lowest setting, just above off. That does not address the parasitic draw, but it does help at night. Also, I installed a curtain at the opening to the bed in our 179. That is to let me get up earlier than my wife, who likes to sleep in later.
Tars Tarkas View Drop Down
Post Options Post Options   Quote Tars Tarkas Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2020 at 12:05am
This is a fine solution for getting the light to turn off at night when you don't want to see it, but just be aware that it does little to prolong your battery life.
fffriedl View Drop Down
Post Options Post Options   Quote fffriedl Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2020 at 9:48pm
Do you remember what color the wire is that you installed the toggle?
Frederick F Friedl
Post Options Post Options   Quote fffriedl Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2020 at 9:47pm
Thank you. Very ingenious. I will install one too
Frederick F Friedl
Pod People View Drop Down
Post Options Post Options   Quote Pod People Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2020 at 9:05pm
We boondock a lot and I did not want his light to be active.  I installed an in-line switch on the main power line going into the entertainment unit.  I unscrewed the face of the unit and pulled it completely out of the wall.  This will take 2 people because all of the wiring is relatively short, so 1 person has to hold the unit while you work on it. I found the main incoming power line and cut it. I added a simple on/off toggle switch in this line and reinstalled the entertainment unit back in the wall.  I made a base plate for the switch(also holds the end of the curtain between the bed and living area). It works perfectly.
Vann
Vann & Laura 2015 RPod 179
Post Options Post Options   Quote fffriedl Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2020 at 6:20pm
Gotcha......Thank you
Frederick F Friedl
Post Options Post Options   Quote Tars Tarkas Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2020 at 6:05pm
No.  But there are also other parasitic 12v draws.  The fridge computer board runs on 12 v no matter how it's powered, and the CO detector.  Maybe that's it.  The answer is to store the pod with shore power hooked up, remove the battery, or install a battery cut-off switch.
