  New Posts New Posts RSS Feed: Refrigerator beeping
Topic ClosedRefrigerator beeping
mjlrpod View Drop Down
Direct Link To This Post Topic: Refrigerator beeping
    Posted: 15 Apr 2020 at 7:09am
Originally posted by Wirat
Riotkayak, do you have a photo of this area you can share? I would like to see and be sure in case it happens to me down the road. Thanks
Heres a youtube link that shows how to fix the issue. If I were doing this, I would use even more grease in there. Make sure you use dielectric grease, or bulb grease.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
riotkayak284 View Drop Down
Direct Link To This Post Posted: 15 Apr 2020 at 8:00am
Just look on the side by the door latch. You will see indention in the fridge sides, one is covered by a white piece of tape. Just pull it off and fill with silicone...
Direct Link To This Post Posted: 15 Apr 2020 at 8:02am
https://www.forestriverforums.com/forums/f197/refrigerator-beeps-106640.html
Direct Link To This Post Posted: 15 Apr 2020 at 8:33am
Also, where the wire comes down to the latch, form a drip loop in the wire. That will also help since it is hard for water to run uphill. It doesn't take a big one.
cosmo751 View Drop Down
Direct Link To This Post Posted: 15 Apr 2020 at 9:10am
I believe you need to look further. How do you think the moisture is getting in there in the first place?
In my refer there was considerable space for air leakage around the back panel of the refer. In addition to trying all the other recommended fixes (which didn't sure the problem) it was necessary to seal every potential opening in the inside of the box. I used aluminum HVAC tape and silicone sealer - use your best judgement. The door seals and the latch ass'y seem to be working fine on their own.
And yes, the electronic source of the beeping is the moisture condensing on the door switch contacts.
  Bingo - no more beeping. Ever. Argue if you will (someone will!) but this is actually fixable. By you!
Lastly, be sure and follow your mom's advice - Keep the door closed as much as possible. It ain't a t.v. set !
"He not busy being born is busy dying."
Kahonu37 View Drop Down
Direct Link To This Post Posted: 25 Jul 2020 at 4:11pm
This may be just a little off, but my LED light on our 2018 DOMETIC RM 8501 fridge interior light stopped working. Appreciate any input
2018 179
2012 NISSAN XTERRA (retired 12/19)
2019 RAM 1500 WARLOCK (new)
A.R.E. V Series Topper
WDH Equalizer 600/6000
Motor7 View Drop Down
Direct Link To This Post Posted: 09 Aug 2020 at 6:33am
Mine started the same thing yesterday...off to remove and disassemble switch. Thanks to all for the great info!
2016 R-Pod 176T
Direct Link To This Post Posted: 09 Aug 2020 at 10:44am
I made a small drip loop in the wire leading to the switch to help prevent moisture from running down into the switch. I think that helps also.
Tibof View Drop Down
Direct Link To This Post Posted: 13 Aug 2020 at 5:11pm
This issue is due to a manufacturing defect in the door switch that allows moistures to collect and condense..  Dometic knows about it.  The silicon fill does work.  A new switch is very expensive, and you have to be sure to get the correct right or left one.  I no longer have the part number.
2015 Pod Hood River Edition
2012 Tacoma Crew Cab 4 Liter
