  New Posts New Posts RSS Feed: R-pod 195 Pantry
Topic ClosedR-pod 195 Pantry
mjlrpod View Drop Down
Direct Link To This Post Topic: R-pod 195 Pantry
    Posted: 02 Apr 2020 at 7:59am
On our last trip out in October last year, the pantry suffered a failure. The pantry is huge, and it has 4 shelves that you can adjust the heights. If you have a 195, 196, not sure about the 192, 193, you'll know what I mean. I keep 2 plastic bins on each shelf, that keeps thing from rolling around. I can put a bunch of stuff on each shelf. So last year the plastic shelf holders broke. I have replaced them now with steel rails, that have steel adjustable clips. I am pretty sure this system won't fail. If you tend to fill up the pantry, you might want to replace the plastic strips with steel.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Yedi View Drop Down
Direct Link To This Post Posted: 30 Apr 2020 at 9:27pm
What exactly did you replace it with?  Can you give me specifics?  Thanks!!
Direct Link To This Post Posted: 01 May 2020 at 10:32am
Amazon has these. It requires four, 4 foot long sections.  I ordered 3 6 foot steel bars, with about 20 clips. I cut 3 bars 4 feet long, then used two 2 foot bars for the fourth. I had to add a spacer on one side cause these bars are thinner. I bought some 3/8 strapping and mounted them to shim the opening a bit smaller.  Heres the part number for the rails
Knape & Vogt PK255 ZC 72", Zinc
2020 R-pod 195
I'll be rpodding
