Topic: Water Heater Posted: 10 Mar 2020 at 3:13pm |
Originally posted by mdballou
Also, I made the mistake and did not have the camper level for the gas to heat the water. Need to be real close to level. |
I knew that the refrigerator is sensitive to level (or lack thereof), but I did not know the water heater was.
Posted: 10 Mar 2020 at 3:57pm |
I knew that the refrigerator is sensitive to level (or lack thereof), but I did not know the water heater was. |
I don't see why the water heater would be sensitive to level, unless it was so far off that the burner couldn't ignite or function properly. That would require very significant angle. Level considerations don't show up as an issue in the water heat troubleshooting guide.
Colt
Posted: 10 Mar 2020 at 4:16pm |
Found and fixed! mjlrpod called it. The middle bypass valve was open so as soon as the pressure equalized in the tubes, the slug of warm water went lukewarm and a shower was rough. Thanks!!!!
John
'16 R-Pod 180
mjlrpod
Posted: 15 Mar 2020 at 8:26am |
Glad you found it, and thanks for the update. It's very helpful when people report back that the problem is solved, and what fixed it.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Posted: 28 Apr 2021 at 9:20am |
Did you also find the switch to put the WH on electric? As far as I know, not a single RPod has been built without a 2-way WH. And I know things... LOL
Colt
Posted: 29 Apr 2021 at 9:05pm |
Yes, I did. It does have an electric element, but the switch is hidden behind something and I had to get on my knees and look up to see it.
John
'16 R-Pod 180
Posted: 30 Apr 2021 at 5:52am |
You can also use the breaker that controls the water heater heating element as a switch. Both it and the switch on the water heater behind the hidden behind it's gasworks work but are very inconvenient. Now we are seeing an additional switch on the control panel which is much easier to find and use and is illuminated so that it is clear that it is turned on.
