 Post Reply Post Reply Page  <1 1819202122 58>
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Topic: ouR escaPOD mods
    Posted: 03 Mar 2020 at 7:49pm
Amazon has a 50 ft Camco 10/3 cord for $57, that's about as cheap as I've seen.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2020 at 7:35pm
Originally posted by offgrid
I still think just getting a 10 awg extension cord and reterminating it is probably the easiest and least expensive solution. You could even take the internal ground in the cord and tie it in parallel with the negative (white) conductor and reduce the voltage drop further. You'd  end up with about a half volt drop at 50 feet with a 100 watt solar module at full sun, which should be fine. No sense in wasting copper Tongue
That is probably what I will end up doing as soon as I can find one at a reasonable price. I like the idea of tying the internal ground to the neutral. I am all in favor of cutting resistance if possible.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2020 at 7:32pm
Originally posted by GlueGuy
There is also a wire sleeve like this. You would have to slip it on before you attached the connectors. The advantage is that it would tightly contain the entire wire run without anything to catch.
That one looks like it is best suited for indoors where it has no possibility of being dragged through the mud.
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2020 at 6:51pm
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2020 at 6:37pm
geewizard View Drop Down
Post Options Post Options   Quote geewizard Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2020 at 5:35pm
Originally posted by StephenH
I saw the spiral wound loom and did not like it.
I didn't either and that's why I chose to twist my cables together.  They roll up and fit within the back frame of the solar panel quite nicely.
2004 Outfitter Apex 8 camper
2014 Toyota Tundra DC
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2020 at 3:54pm
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2020 at 9:52am
There is also the spiral wound wire loom like this. You could just use a 12" section of it every few feet. I kind of like it because it is easy to remove without cutters.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2020 at 1:53pm
If the wire loom were not split and if it were more flexible, I might consider that. The problem with shrink tubing is that it is hard to fit over existing connectors. If I were working from just the wires, it would work. I ended up going with the cable ties every couple of feet. I found that I can fit the 25' extension cord in the space behind the panels with no problem.
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2020 at 9:01am
Instead of cable ties, you might consider a wire loom (like this). It will keep the wires together and not tend to get caught up on things. Maybe wrap some tape or shrink wrap every 4 feet or so.
