Page <123> |
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2720 |
![]() Posted: 27 Nov 2019 at 6:48pm |
You could also just put jumper cables between your TV and TT batteries. Jumper cables should be large gauge and would allow the maximum amount of current between the two systems. Then it would be totally dependent on what the state of charge was when you start, and how robust the charging system on your TV is. The alternator on our F-150 goes well above 200 amps; IDK what your TV can do.
EchoGale ![]() Senior Member ![]() Joined: 10 Mar 2019 Location: FL Online Status: Offline Posts: 469 |
Thanks! Living in Florida I won't be "putting the camper up" for the winter so I'm looking for something other than removing the batteries. Now if i can just figure how to READ that multi meter everyone said i should buy. This was helpful.
Julie
You can recharge the TT battery from your TV but you're not going to like it. Several problems: typical TV wiring limits the charging current to about 10 amps from the 7 way connector on the rear. It has to do with small wire gauge between the TT battery and the 7 way connector. So if your two 6V golfers are rated around 200AH and if they are 50% discharged you would have to replace 100AH for full charge. If you could maintain the 10A rate it would you 10 hours!. If you settle for 80% recharge that would require replacing 60AH and take 6 hours at the 10A rate. However, most newer TVs regulate the charge voltage to around 13.8 volts so chances are you will not be able to maintain the 10A rate. Some of this can be overcome by using heavy copper jumper cables directly from the TV battery to the TT battery but it will still require several hours. Considering the times you will have to make the trip and how long you will sit there waiting you should reconsider the alternatives. They are two: solar trickle charger or take the batteries out and trickle charge at home. You might permanently mount a small solar charger on the roof and providing a hole in the cover. Not the best but it will work. The other alternative, taking the batteries home, is still the best tried and true method. Just be sure you reconnect them with the correct polarity in the Spring. |
EchoGale,
you can, in most cases use your TV to charge TT batteries if your TV is set up correctly, a multimeter will assist in determining it is working. It doesn't matter what type battery you install, without a charge or maintain capability they will drain if connected. As for how long, it is determined by the charge of the battery when you start. |
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3366 |
I currently own 2 Interstate 12v group size 24 deep cycle batteries for my 177. Protocol has been the same since 2011, hence these batteries are still working well after nearly 9 years: 1) remove batteries late October/early November and set on concrete floor in our unheated garage (northern Michigan) 2) clean posts and check water levels in each cell 3) 2 amp trickle charge at this time for 24 - 36 hours/battery. 4) leave both batteries hibernate during the winter - nothing done during this time 5) early May repeat step number 2 and 3 above then re-install. Works well. I planned on going with twin 6 volt batteries many years ago but the ones I currently own refuse to die so until that happens I will continue to use them.
ArenaBlanca ![]() Senior Member ![]() ![]() Joined: 07 Sep 2016 Location: Alamogordo, NM Online Status: Offline Posts: 158 |
If you decide to "plug in" using extension cords, remember to turn off the water heater first or at least have water in it. Otherwise, you can burn out the heater element in a hurry. Don't ask me how I know this.
Enjoy Life!!
Thanks, glue guy. The batteries are too heavy and its too far for me to move them. I've thought about the solar charger but I i think the charger would get stolen (plus i keep everything covered). So...my initial question: can I do this by hooking my TV up regularly?
Julie
If you need to store your pod where there is no power, I would consider removing the battery(ies) and put them someplace where you can trickle charge them. Another option would be a small solar-powered battery maintainer (something like this)
I've been wondering about this myself. I bought my camper used with batteries needing to be replaced in the near future. Its getting close to that now and I will by golf cart batteries as per advice on this forum. Before the expense though I need a plan to keep them from losing charge. My pod is parked where I have no power.
My question: assuming I remember the cutoff switch, can I boost the batteries once a month by hooking them to my TV? If so, how long should that take? Thanks for any advice. Julie
Julie
Even with the battery disconnected, it will drain, although more slowly. If the battery is completely disconnected from any loads, it would still need to be boosted once every 4-6 weeks.
Page <123> |
