  New Posts New Posts RSS Feed: drain caps
Topic Closeddrain caps
harrypodder View Drop Down
Direct Link To This Post Topic: drain caps
    Posted: 23 Oct 2019 at 4:14pm
D
crw8sr View Drop Down
Direct Link To This Post Posted: 23 Oct 2019 at 4:55pm
Don't know that, but I went to Menard's and purchased pvc shut off valves and screwed them on.  Work great.
Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
Direct Link To This Post Posted: 23 Oct 2019 at 8:53pm
Just put on some shut off valves.
Direct Link To This Post Posted: 24 Oct 2019 at 5:28am
I appreciate the suggestion of drain valves which I would consider but I travel during freezing weather and any piping extended and exposed to the elements is subject to freezing. My drains are tight up against the underbelly board to lessen the chance of ice up that is why I use the caps.
riotkayak284 View Drop Down
Direct Link To This Post Posted: 24 Oct 2019 at 9:25am
I found them on Amazon.
https://www.amazon.com/Flair-16860-Plastic-Fitting-Size/dp/B000H602C8/ref=sr_1_4?crid=1CDRHQZ3ALBQ5&keywords=rv+water+line+cap&qid=1571927112&sprefix=rv+waterline+%2Caps%2C145&sr=8-4
crankster78 View Drop Down
Direct Link To This Post Posted: 24 Oct 2019 at 6:32pm
Greetings:
Find a local RV dealer.  They should have them.  I found them at mine.  They are inexpensive so buy a few to have.  It's pec pipe, a Home Depot, or Lowes might have them.
Crankster78  R-179
Crankster 78 R-179 2015
Direct Link To This Post Posted: 25 Oct 2019 at 3:46pm
I would take one to Lowes or Home Depot, agree they are PEC.
Direct Link To This Post Posted: 26 Oct 2019 at 7:46am
To clarify the plumbing in rPods is half inch PEX tubing. PEX is great to work with and the most common plumbing system used these days. You can get push on fittings (Sharkbite is one brand) or you can get clamp fittings and a clamping tool. Either are available at any big box hardware place.
Direct Link To This Post Posted: 26 Oct 2019 at 7:59am
Greetings:
Sorry I meant PEX  senior moment
Ermm   Crankster78
Direct Link To This Post Posted: 26 Oct 2019 at 10:15am
Originally posted by crankster78
Greetings:
Ermm   Crankster78
I blame those on a keyboard malfunction. The C is just to the right of the X on the keyboard, so the keyboard is at fault.  Wink
