Monemkr2000 ![]() Newbie ![]() ![]() Joined: 15 Nov 2018 Location: North Carolina Online Status: Offline Posts: 17 |
![]() Posted: 06 Oct 2019 at 5:26pm |
So I'm trying to get the cable to work. Ive hooked up the cable line from the pedestal to the POD. But when I go to scan for channels it's not picking any up. Is there a switch some where (2019 190 ) that I'm missing to get it to switch from the antenna. I thought the TV did the switch but maybe not??
"We must always be aware that suddenly and unexpectedly we may find ourselves in a role where our performance has ultimate consequences."
When you are trying, do you have the antenna booster turned on or off? For cable viewing, it should be turned off. I have not tried it since we don't have cable, but that is what I have read. You may need to check the source the television is using also and change from antenna to cable, then you may need to scan for channels, but I am not sure about that. Also, one other thing to check: See if the cable connection on the post is an active connection. It may be there, but may not have an actual signal going through it.
Buckeye ![]() Newbie ![]() ![]() Joined: 20 Jan 2019 Location: LSL, MO Online Status: Offline Posts: 37 |
Happened to me when I connected to the cable port on the Pod (the one on the left) from the origin. Then I connected it to the aux port (the one on the right) and it worked.
Craig-retired teacher of the blind
Carol-retired legal admin asst Spot and Sam-the miscreant Shih-tzus "Politically incorrect with no real changes expected...” Former 2017 Rpod 180 F150 5.0 4x4 |
My R-pod only has one port. It says Cable/Satellite. Unless Im missing one somewhere. Did find a workaround. Just run the cable thru the slide out. Works until we get home and figure out what's going on.
