  New Posts New Posts RSS Feed: Non Emergent General Questions
Topic ClosedNon Emergent General Questions
mdballou View Drop Down
Direct Link To This Post Topic: Non Emergent General Questions
    Posted: 23 Sep 2019 at 5:54pm
Just a suggestion, sounds like your troubleshooting is on par. Make sure connections to the 30a breaker are good and tight.
Direct Link To This Post Posted: 23 Sep 2019 at 4:18pm
Pod People,
No issues with sag or support here. I was under slide on inside a couple years back and could see light at the bottom. Along track at bottom, just to be safe I keep it closed in storage. My wife hates mice.
Direct Link To This Post Posted: 23 Sep 2019 at 4:12pm
I did run a test today, about 2 hours worth. Another 90 degree day so temp was up. I started first test from cold start, Pod on 120/30A service from building. AC ON, Micro ON, WH ON, Reefer 120 ON, a light ON, a 12 " fan ON, TV ON, Converter ON. Initial DC Battery Voltage at 13.1 Volts DC. Approx. 30 minutes into run the 30A CB in Pod tripped. The 30A CB at power source did not. I didn't notice anything happening when it tripped, the WH had completed a heat cycle, so it ran all the way thru WH heating. One notation - when I glanced at the DC Batt voltage it was a t 14.5 volts, resetting caused Batt voltage to go to 13.6 Volts. Not convinced it is issue but it does tell me the charge circuit is working.
2nd run, basically started over with a cool down and drained HOT water, so cold water was in WH. Again, 30 mins into the run the 30A CB in trailer tripped. Basically same notes, WH was HOT, nothin noticeable happened. Did note the Batt voltage was at 13.6 VDC.
For me, in the 5 years I owned this Pod, I have never had this much stuff on for this amount of time. That's why I have never seen it happen on site. I know for a fact I have never run the Micro for 30 mins continuous ICW the AC, but the note was it runs for 30 mins. I couldn't justify the WH having an effect. Rain came in and forced me to continue another day, plan is to disable things and try to see exactly where the where issue is. I do have a clamp on ammeter, once determined where to monitor, will do.
Pod People View Drop Down
Direct Link To This Post Posted: 23 Sep 2019 at 8:13am
Our 179 slide is in the out position when stored at home during camping season.  Once winter arrives we will bring the slide in and put on the pod cover until spring. I haven't noticed any problems with insects or critters getting in or any sagging of the slide. We don't have any additional support when it is in the out position.
I would also like to know more about this issue if anyone has any information.
Vann
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 22 Sep 2019 at 4:25pm
I'm going to test this. I have everything to do it here at house. Will report the result. I've lived in my Pod for 3 months, water heater heating, AC running, microwave cooking and never kicked a CB on a 30 A service. Wouldn't make a lot of sense to buy a 3K generators would it? The Pod wouldn't handle the requirements.
TearlessTom View Drop Down
Direct Link To This Post Posted: 22 Sep 2019 at 1:27pm
It is the fuse panel under the seat by the door.
We were running on a 30A hook up at the state park and had a surge protector inline.
Also the carbon monoxide sensor goes off very easily when an air freshener or cleaner (Lysol) is sprayed. It seems overly sensitive. Don't know if that means anything or not.
Tearless Tom
2017 R-Pod 180
2014 Ford F-150 XLT 2WD 5.0
Direct Link To This Post Posted: 22 Sep 2019 at 12:29pm
I forgot the electric for the water heater. We never use it, as we get all the hot water we need from propane. If you take the WH via electric out of the equation, you should be good. At least we have been.
CharlieM View Drop Down
Direct Link To This Post Posted: 22 Sep 2019 at 9:21am
The WH electric element draws 12 Amps when it's heating. The AC takes 13-15 Amps when running, more when the compressor starts, and the microwave takes 12+ Amps when heating. You can usually run any two but not all three simultaneously. The exception is the WH that draws zero if the water is already at temperature. One solution is to turn the WH breaker off temporarily if you run the microwave. If you forget to turn the breaker back on you will either end up with cool water or it will revert to gas if you have the gas switch on. Not life threatening either way Wink
Direct Link To This Post Posted: 22 Sep 2019 at 8:58am
+1
You should be able to run everything when on a 30 amp service. The biggest draws for power are the A/C, Microwave, and the converter. Probably in that order.
If you're popping a breaker, you should check witch one(s), and possibly check the line voltage. If the line voltage is a bit low (like 100 volts maybe), the amperage draw will be higher, and "might" throw a breaker.
Direct Link To This Post Posted: 22 Sep 2019 at 8:34am
Hi Tom,
When hooked to 30A power, I can run every power appliance in my POD. Not sure where you are obtaining power and if that power is 30As. I have a 30A service on my outbuilding and have no issues running POD. What breakers are you tripping? A lot of folks use Easy Start mod, but you shouldn't need that on a 30A service.
As far as storage, I store with slide in. I don't have issue with slide support, but keep it closed for two reasons. 1 it takes up less room in my building and I use winter time to do outside maintenance. 2 - I have noticed when it is open it is not sealed as well as when closed, especially along the bottom. My storage area has rodents, critters and bugs. I like to keep them out of the interior, so I seal the Pod as well as possible.
Mattress I can't help you with, I replaced mine first week with a 10" (mistake) and it is darn near impossible to remove it from the Pod:).
