  New Posts New Posts RSS Feed: Whats pulling your RPod
 Post Reply Post Reply Page  <1 3536373839 46>
Jeepinator View Drop Down
Post Options Post Options   Quote Jeepinator Quote  Post ReplyReply Direct Link To This Post Topic: Whats pulling your RPod
    Posted: 31 May 2019 at 7:41am
Originally posted by TarHeelPod
Yeah I know the rakes the weight off the hitch and distributes onto the axle.
Is there something else I should know?
TBH I’m still sorting this out but apparently our RPod axles are known for bending.  There is a couple different models and I have the Lippert.  I’m trying to determine the how much more pressure I have put on the axle with my current WDH configuration.  I’m sure someone will weigh on on the best way to do so.
2018 Jeep Wrangler Willys
2017 179
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2019 at 8:33am
Best way is to weigh your axles with and without the wdh tensioned. My trailer axle weight goes up about 120 lbs but the actual amount of increase will depend on your particular rig and wdh tension setting.
Lheins View Drop Down
Post Options Post Options   Quote Lheins Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2019 at 12:17pm
2018 Ford F-150 Supercab 5L V8 pulling a R-190
Lheins
jdreed@frontier.com View Drop Down
Post Options Post Options   Quote jdreed@frontier.com Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2019 at 5:18pm
The wife and I just got back off the road after a four and 1/2 month long wandering road trip from Seattle, WA over to Maine, down the East coast as far as Jacksonville FL then across to Mississippi, then back up wandering through Kansas, Colorado, Utah, Oregon and back home to Seattle. total miles 14,102  average MPG over all 12.5 crusing between 60 and 65 Mph there were lots of stops with family along the way and of course sighting at all the many cities along the way.
My 2015 TOYOTA Tacoma 4X4 sport model V-6 four door w/6' bed performed with out any problems.  The only mod from stock was to add a larger transition oil cooler. We stoped for oil changes and tire rotations about every 5k checking tire wear regularly. (last check was 6/32 all round)
there were many miles of back roads, not in the best of condition, but just took to easy and enjoyed the views.
opps! forgot to add our R-Pod is a 2018 R179 Hood River edition.
seafans View Drop Down
Post Options Post Options   Quote seafans Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2019 at 8:24pm
The2005 Murano only has a 3500 lbs towing capacity.  Most of these trailes come in about 3000 empty.   I have a Pathfinder  with the same engine and a 5000 lbs tow capacity and it can be a struggle up the hills.  Nissan is coming out with a 2021 Frontier with a 300 hp engine with 7 speed transmission  that I have my eye on.
malkbean2 View Drop Down
Post Options Post Options   Quote malkbean2 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2019 at 8:31am
fyi
just completed a trip over the rockies eastbound on I70 in Colorado pulling a 178 with a 2016 Grand Caravan. Did Vail pass at 40mph @ 3500 rpm. Approach to Eisenhauer tunnel (10700 ft) was more painful- slowed to 30 mph at 4000rpm and engine got warm but not redline. (AC off and heater on)
Conclusion: The minivan can do it but it echoes the refrain- more power is desirable.
rpod 178
Grand Caravan
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2019 at 8:42am
Ah! The Ike Gauntlet! It is a well known challenge: https://www.tfltruck.com/tfltruck-hall-ike-gauntlet/
Or the latest here.
7mm sendero View Drop Down
Post Options Post Options   Quote 7mm sendero Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2019 at 10:30pm
2014 Silverado Crew Cab and topper, it’s the 6 cylinder version.   Plenty of truck, nice to not require anything special for towing.
Woodmiester View Drop Down
Post Options Post Options   Quote Woodmiester Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2020 at 2:50pm
We pull our 190 with a 2004 sport trac with a 4L V6. Does a great job.
Swampfox
Chopperbob View Drop Down
Post Options Post Options   Quote Chopperbob Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2020 at 7:15am
2019 Honda Ridgeline RTL AWD pulling our new 191 East Coast model.
We purchased the 191 near Boone, NC and we’re on the Blueridge Parkway/ Meadows of Dan RV campground.
Marveling at the Design!
