  New Posts New Posts RSS Feed: 6000 fantastic miles
Topic Closed6000 fantastic miles
gpokluda View Drop Down
Direct Link To This Post Topic: 6000 fantastic miles
    Posted: 28 Aug 2019 at 8:52pm
We completed over 6000 miles with our 179 this summer. Made some mods along the way
  • additional shelf in the top pantry cabinet
  • soft storage for the person sleeping against the front wall
  • dual batteries
  • kitchen wall racks for utensils and misc
  • all outlets replaced with outlets plus USB
  • Harbor Freight TV mount mod for tilting TV mount
A few things we learned along the way
  • White electrical outlets are easier to see than black ones
  • Stock trailer electrical outlets are awful (how are these allowed?)
  • 1" deck screws work great in the walls (just add a little glue to the screw to keep it secure)
  • Always carry a scissors jack and some 2X4 scraps
  • The stock vinyl trim falls apart quickly but is easy to replace
  • A weight distribution hitch is a must (air bag suspension is next on our list)
Gino
2016 Rp179
2016 Nissan Frontier SV
2018 Triumph Bonneville
Direct Link To This Post Posted: 29 Aug 2019 at 5:04am
Sounds like you've had a great summer and have learned a lot and have things dialed in.
On the air bag suspension, it can be tricky to use that in combination with a wdh.
The wdh works because the tension bars are applying a torque to the TV rotating the front axle down. If you set that up and then inflate a rear air suspension you are reducing the bar tension and moving more weight back to the TV rear axle from the front.  Since the most important thing is to get the load on the front axle right while towing its generally best just the to use the wdh alone. As long as you have the tow vehicle axle loads well within specs it doesn't hurt anything to have a little rear axle squat, the TV was designed for that.
If you do use the two together then I'd suggest setting the wdh bar tension after inflating the air bags, that way you know you have the front axle load right.
Direct Link To This Post Posted: 29 Aug 2019 at 10:00am
An alternative to air springs is to install a set of SumoSprings instead. These are Urethane springs that don't need to be inflated, can't leak, and are available in three different grades depending on your needs. I installed a set of the blue ones (1,000 lb), but recently changed them for the black ones (1,500 lbs). Our 2010 Frontier's suspension was quite mushy before installing the SumoSprings. Now it s firmer, but not uncomfortable. I can hit a bump without bottoming out the suspension.
In the Frontier, the SumoSprings replace the stock bump-stop. As long as you have a breaker bar, the correct deep socket, a torque wrench, and a good jack (a hydraulic floor jack works great), it is something you can install yourself. It does not take too long to do so.
Direct Link To This Post Posted: 29 Aug 2019 at 4:46pm
+1 to OffGrid and SH, not an airbag fan. Depending upon TV, WDH may be good idea. I'm a Sumo fan to a point. WDH is single best option.
Direct Link To This Post Posted: 29 Aug 2019 at 4:48pm
+1. With a properly adjusted WDH, no suspension mods should be necessary (assuming the vehicle is good for the load).
Linda&Gino View Drop Down
Direct Link To This Post Posted: 29 Aug 2019 at 8:16pm
Thanks, OffGrid. The plan was to set the airbags first, then set the WDH but I just haven't been able to pul the trigger. I only need the airbags once in a while so it is hard to justify the cost. I don't have any handling issues. Thanks. I appreciate the info.
Direct Link To This Post Posted: 29 Aug 2019 at 8:29pm
Thanks everyone for the feedback. Lots of food for thought.
Direct Link To This Post Posted: 29 Aug 2019 at 9:43pm
Actually, the WDH by itself (Hensley Cub) did not seem to be adequate with our older Frontier. With the SumoSprings, it is much better.
Direct Link To This Post Posted: 30 Aug 2019 at 5:19pm
I believe that to be true most of the time, but not all of the time. I can see someone being able to get their WDH setup spot on every time they hitch up with the chain style WDHs. I have a Fastway with spring bars instead of chains. Since the adjustment requires the hanger bracket to be relocated by unbolting it and then bolting it back in its new position, it would be way easier to simply have suspension assist to trim up the difference.
But you are right. If you carry a consistent load every time you hitch up and your TV's rear suspension isn't sacked out, a well adjusted WDH is all you really need.
Olddawgsrule View Drop Down
Direct Link To This Post Posted: 31 Aug 2019 at 4:16pm
Personally, I jumped in here to learn where you went? 6K is a good run and plenty to be seen where-ever!
This curious mind wants to know where you went?
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
