  New Posts New Posts RSS Feed: WET BATH SURROUND NOT GLUED DOW.
Topic ClosedWET BATH SURROUND NOT GLUED DOW.
Grummy View Drop Down
Direct Link To This Post Topic: WET BATH SURROUND NOT GLUED DOW.
    Posted: 14 Aug 2019 at 11:56am
I AM CONCERNED RT THE WALL COVERING IN MY WET BATH 2019 RPOD 179. IT DOES NOT APPEAR TO BE GLUED DOWN. I AM WONDERING IF THIS IS THE EXPECTATION OR DOES IT NEED TO GO IN FOR REPAIR. PICKED UP NEW APRIL 2019.
Direct Link To This Post Posted: 14 Aug 2019 at 11:58am
Pretty sure they don't get "glued down".. so that IF moisture gets behind them it can get out...
mjlrpod View Drop Down
Direct Link To This Post Posted: 14 Aug 2019 at 12:33pm
The shower surround in the 2 units I have had, was held at the top and the bottom. I think the majority of it is "free floating". Before 2017 the shower didn't even have a plastic surround on them, It was the same finish as all the other walls. I don't think you need to worry.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Olddawgsrule View Drop Down
Direct Link To This Post Posted: 14 Aug 2019 at 2:43pm
I've heard of this a few times now. Seems most use 2 sided epoxy tape and some sealant to fix.
I'll let others that have repaired successfully decide if it a good fix or not. I also need to do mine.
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
