  New Posts New Posts RSS Feed: Solar question
  FAQ FAQ  Forum Search Search  Calendar Calendar  Register Register  Login Login
Topic ClosedSolar question
Direct Link To This Post Topic: Solar question
    Posted: 02 Aug 2019 at 3:00pm
I just installed a lighter socket and tied it into the 12v supply for the stereo. If you get one with USB ports you can add those at the same time for mobile device charging.
Motor7 View Drop Down
Direct Link To This Post Posted: 07 Aug 2019 at 8:19am
Originally posted by Babysaph
So does the 12v solar fan just plug into an outlet in the camper?
Yes, you can always add more 12v outlets or even change over to a different type.
This is the fan we use:
https://www.amazon.ca/Fan-Tastic-Vent-01100WH-Endless-Breeze/dp/B0000AY2Z6
2016 R-Pod 176T
Olddawgsrule View Drop Down
Direct Link To This Post Posted: 16 Aug 2019 at 1:08pm
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
Direct Link To This Post Posted: 16 Aug 2019 at 4:29pm
I use a couple of these or the equivalent, there are multiple sources. i can clamp them to the valances in front of the open windows where we want them and the oscillation is nice. You will need a cigarette lighter adapter somewhere convenient, but you can get both wye two from one adapters and extension cords in the 12V lighter plug format for flexibility.
