  New Posts New Posts RSS Feed: BAL Hide-A-Spare on RPOD?
Topic ClosedBAL Hide-A-Spare on RPOD?
geewizard View Drop Down
Direct Link To This Post Topic: BAL Hide-A-Spare on RPOD?
    Posted: 30 Jul 2019 at 2:21pm
Anyone use a BAL Hide-A-Spare on an RPOD?
2004 Outfitter Apex 8 camper
2014 Toyota Tundra DC
Direct Link To This Post Posted: 30 Jul 2019 at 2:32pm
We just installed one. Our's is a Hood River Edition, so the spare is a bit on the jumbo side. Took a shoehorn, but we got 'er done. We mounted the thing with 5/16" SS bolts, and they have to be drilled ALL THE WAY to the bottom of the frame. It just fits.
Direct Link To This Post Posted: 30 Jul 2019 at 3:19pm
Good deal.  Which model Hide-A-Spare did you buy?  And what do you mean "they have to be drilled ALL THE WAY to the bottom of the frame."?  It looked to me as if the attach hardware mounts horizontally into the side of the frame.
Mine is a HRE as well with the bigger spare tire.
thanks.
Motor7 View Drop Down
Direct Link To This Post Posted: 30 Jul 2019 at 8:56pm
I used large self tappers for mine. Just did 1600 miles and did have some screws come loose....none were on the Hide a Spare.
I can't remember the model # but you will have to cut the rails to fit our frames.
2016 R-Pod 176T
Direct Link To This Post Posted: 31 Jul 2019 at 8:21am
thanks.
I think ours is the 28217. The brackets "step out" on both sides. That said, we had to shorten the extension tubes by about 5 inches and re-drill the holes. It wasn't exactly plug-n-play, but it was not complicated.
We had to use the holes at the very top of the mounting brackets (2 on each side), and we had to place the holes through the frame as close to the bottom of the frame as they would go; about 1/2" above the bottom of the frame members.
We used 3" SS bolts plus SS nyloc nuts. Don't forget the anti-seize. In a moment of absent thought, one of our bolts did not get anti-seize, and the nut seized up. We had to cut it off and start over on that one.
Direct Link To This Post Posted: 31 Jul 2019 at 9:09am
thanks.
I ordered the 28217 yesterday.  I appreciate the details.  SS hardware is a pain but the way to go.  Thanks.
Direct Link To This Post Posted: 31 Jul 2019 at 11:57am
GlueGuy, have you had any issues with the BAL tire carrier bottoming out when crossing rough terrain, ditches, etc?
Direct Link To This Post Posted: 31 Jul 2019 at 1:41pm
We have not towed with it yet, but it does hang down a bit. In the final position the cross tubes are about the same level as the dump tubes (just scosh higher). The tire is another inch or so higher than that, and forward of the receiver a little more than a foot. Given the angles and stuff, I think the stabilizer jacks will hit first.
crw8sr View Drop Down
Direct Link To This Post Posted: 31 Jul 2019 at 5:38pm
We installed one on our 190.
Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
voisj View Drop Down
Direct Link To This Post Posted: 31 Jul 2019 at 8:27pm
Here's a pic of mine I had to set it lower by 1.5" so the hood river tire would fit.
Also shortened the tubes 6" And on the 180 the carrier sits just in front of thew tires and Iv'e had no issues with ground clearance.
SLOPODMODS
John&Sue,SLO,CA
