Page <12345> |
![]() Posted: 30 Jun 2019 at 4:16am |
Yeah, I agree on the 4 wheel set, if you want to wear out all 4 tires on a vehicle at once, then by all means rotate them. That's particularly a good idea if you want to extend tire life because you're planning to sell or trade pretty soon.
Since I'm cheap and keep my vehicles pretty much forever unless someone hits me, I just leave the tires where they are. I have found on my fwd passenger vehicles that the rears last somewhere between 1.5 and 2x as long as the fronts. I end up buying two tires at a time rather than 4. I like that for the same reason I keep my cars forever. ![]() On a drive axle you probably want to change both sides at once to minimize differential wear and to allow the vehicle's ABS to work optimally. I don't think it matters on a trailer axle as long as the tread depth is adequate on both tires. For that matter if you have 15 inch wheels but run a 14 inch spare on an rPod axle until a new tire can be bought I don't think that matters much either, but I'd be interested in other's thoughts on that one. |
Actually with no tire wear, rotation on a trailer is an owner decision, on a vehicle I completely understand the requirement, the fronts corner and turn, the rears track. There is more wear associated with front tires than rears, especially in a front wheel drive vehicle. Rotation increases the longevity of a 4 wheel set.
Good question, maybe we could ask every tire maker who suggests rotation, maybe they are just BSing us.
Not arguing, just learing, I might have missed something. If tires are wearing evenly why do you think you’ll get more longevity by moving them? |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6428 |
I was not talking about rotation, just that the spare should also be a LR D tire if the two on the ground are. Plus, if the spare is several years old, even if it is unused, it is at risk of failure from everything I have read. Better to have a spare that one can be fairly confident that it will be ready and won't fail, even if tires are not being rotated.
OffGrid,
Understand, but if the tires show no alignment or abnormal wear, I believe you'll get more longevity on a set by rotation. I think you have to look at abnormal wear and make a decision and agree it won't be solved by rotation. |
I’ve never believed in tire rotation on any vehicle.. My feeling is that it conceals alignment problems. I’d rather know I have a problem and address it. As far as front vs rear wear is concerned on a modern Fwd vehicle the fronts wear out about twice as fast as the rears and I’d rather replace two tires at a time than 4. That’s just me, everyone has their own way of doing things.
SH,
I admit I didn't do that because of the odd wheel. I will never add spare to side by side rotation, which I do yearly. To me it's a temp tire to get me to repair. I have been looking for a third wheel, however if I did that, I'd go with Offgrid and just upgrade to 15s with 3 matching wheels. Definitely something to think about :) |
Turned out for me that once I added in what it would have cost to get new 14 inch tires mounted on my existing wheels and subtracted what I was able to get for the old tires and wheels on Craigslist I was ahead buying pre mounted 15 inch 2500 lb rated tires and wheels.
The point is that your overall load capacity is no better than your weakest part, so consider both your requirements and each link in the chain when doing an upgrade. For me since I’ve reinforced the axle tube my weakest point is now probably going to be the other axle components (spindle/torsion system). My 179 is heavy. If you have a lighter rpod, don’t boondock, and your axle isn’t carrying in a lot of load then just a tire upgrade when it comes time to replace the OEM tires is fine. |
Page <12345> |
