Page <1 8910 |
![]() Posted: 13 May 2019 at 4:16pm |
One of our members has suggested that but no one has tried it yet as far as I know. The only reason it wouldn't work that I can think of is that you might end up with a higher ride height than you would like. You would still have the same issue with a large overhang between the wheels and the trailer frame so a higher rated axle would probably be needed.
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2709 |
I also think you would have to put a doubler of some sort at the four points where the leaf springs attach to the frame.
+1
texman ![]() Senior Member ![]() ![]() Joined: 24 Jul 2014 Location: TeXas Online Status: Offline Posts: 446 |
Sorry to hear you're having problems. There should be a sticker on the axle which will tell you who made it and what the rating is. If its a Dexter, is the tube flat or turned as a diamond? Can you get the tube dimensions and thickness?
The other thing to do is to see if its crowned (cambered) or not. Run a string line along the bottom and measure the gap in the center if there is one. Re the brakes, if both sides are out its most likely the wiring. If you've convinced yourself that its not a problem in the trailer connector itself, check the wiring to the magnets next. The crummy insulation displacement connectors FR uses are pretty notorious for coming undone. You can also check for voltage at the brake magnet connections with your brake controller connected and energized (by taping the manual lever on or having a helper hold in on). good luck!
The tires on mine were wearing with significant wear on the inside shoulders of the tires. The wheels and tires were definitely splayed out. The dealer where I purchased it did the axle replacement along with brake and bearing replacement. The door side had leaked grease and although I had cleaned it up, the magnet showed signs of excessive wear also so the whole brake assemblies were replaced and a new hub was installed on the door side. The slide side hub was okay. Along with the axle repair, a leak in the slide-out was repaired. The whole job cost me about $3,000. Given how many miles I have been in the pod, it probably worked out to about ten cents a mile.
Page <1 8910 |
