  New Posts New Posts RSS Feed: Caravan Motor Movers
Topic ClosedCaravan Motor Movers - Event Date: 04 May 2019
texman View Drop Down
Direct Link To This Post Calendar Event: Caravan Motor Movers
    Posted: 06 May 2019 at 2:04pm
i use a trailer dolly.  it is not the easiest solution, but gets it done.
TexMan 2015 182g
2018 Sequoia
TexManMods
dfmillard View Drop Down
Direct Link To This Post Posted: 06 May 2019 at 2:21pm
Hi Grandpa,
May I ask where you purchased your mover and where you had it installed?
Rev Dennis F Millard
Grandpa Hiker View Drop Down
Direct Link To This Post Posted: 06 May 2019 at 2:27pm
I got mine from Purple Line http://www.purplelineusa.com/. I dealt with Paul Liner & got great service.
I installed it my self. It came with very detailed & easy to follow instructions.
Rob & Becky
2015 R-179 Pod aka Piddle Pod
Direct Link To This Post Posted: 06 May 2019 at 2:32pm
   We have a old Power Caster that belonged to my father, was only used a few years. It has been in storage ever since about 25 years. I plugged it in a couple of years ago and it worked fine forward and backwards. If someone wants to buy it I will sell it, but they would need to pick it up at our home, it is very heavy.
2014 Ram 1500 Quad cab
Direct Link To This Post Posted: 06 May 2019 at 4:57pm
David, do you know what model it is?
Direct Link To This Post Posted: 06 May 2019 at 5:37pm
  It is a PC-3 1,200 Lb
Direct Link To This Post Posted: 06 May 2019 at 5:58pm
That's the big boy. What do you want for it?
Direct Link To This Post Posted: 06 May 2019 at 7:52pm
$300.00   The large electric motor may be worth that much.
Direct Link To This Post Posted: 07 May 2019 at 5:00am
Originally posted by GlueGuy
Maybe in some cases, but the caravan mover allows maneuvers that are literally impossible with anything bigger than a lawn mower. The e-go, in particular allows you to spin the trailer on its axis. In addition, it allows you to walk around the trailer as you move it, so you can inspect all the potential obstacles. You can even park the trailer "tongue in" if you are in a place where the best view and/or the hookups are on the wrong side.
I get that, I can see the value if you have a really tight storage location, for sure. Probably why these are more popular in Europe where most everything is more tightly spaced.  You don't see a lot of folks diving around in full size vehicles there either. But for most parking spots in North America I would think that either towing from the rear or pushing from the front would be adequate.
One of the nice things about rpods is the narrow width. You still have to leave room for the wheel track but you can turn the corner into or out of a pretty small parking slot without as much stress as you have with an 8 ft wide trailer.
Online Status: Online
Direct Link To This Post Posted: 07 May 2019 at 8:02am
[QUOTE=David and Danette]$300.00   I would be willing to pay that and come and get it. I wouldn't be able to come and pick it up right away though.
