FYI: I'm currently towing with a 2010 Escape, and I just had work done on the transmission - with less than 16,000 miles on the car - I'M NOT A HAPPY CAMPER!! The front drive axle had to be removed and the following parts had to be replaced: a bushing, multiple supercessions(?), shaft-front axle, and differential oil seal. This problem did not happen while towing. I found fluid dripping on my garage floor, and took it in, thinking it was a loose oil filter or oil pan plug, since I'd just had it in for an oil change the week before.
The service guy said they've been getting service alerts on the Escapes for this problem - great.....
I'm towing within my limits, both weight of trailer and hitch weight. Apparently, the Escape isn't up to the job. Escapes that don't tow are even having this problem. Grrrrrrr.......
Google Ford Escape+transmission problems and quite a few links will come up.
Looks like I may be searching for a new tow vehicle and take a beating on my trade in...
