Tire rubbing fender . Looking for advice |
Post Reply | Page <1234> |
Topic: Tire rubbing fender . Looking for advice Posted: 26 Apr 2019 at 9:41am |
john in idaho
Posted: 27 Apr 2019 at 9:22am |
On my 179, the slide side has the fender mounted flush with the bottom of the trailer. The other side has the fender mounted flush with the top edge of the kedder rail. About an inch difference.
Posted: 27 Apr 2019 at 9:25am |
Maybe it's the difference between HRE and non-HRE?
Posted: 27 Apr 2019 at 11:13am |
Also depends on whether there is a keder rail or not. Mine does not so the fender is mounted the same on both sides.
Posted: 27 Apr 2019 at 11:34am |
My 2015 Non-HRE 179 has the keder rail but it is not continuous, allowing the fenders to be the same height on both sides. So it looks like there are at least three different versions?
I was under the impression that Tent2pod's 1 inch side to side difference was to the trailer frame not to the fender but can you confirm?
Posted: 27 Apr 2019 at 12:39pm |
Ours has the keder rail on the curb side, but there is a piece of trim under the slide out that is about the same width as the keder rail. The fender is mounted just a "skosh" above that trim piece.
john in idaho
Posted: 27 Apr 2019 at 12:51pm |
Sounds like the position of the fender depends on who was building trailers that day. Ours is a west coast HRE .
tent2pod
Newbie Joined: 13 Mar 2019 Location: Western pa Online Status: Offline Posts: 9 |
Posted: 27 Apr 2019 at 6:31pm |
[/QUOTE]
Offgrid , I have it sitting on a cement floor . I checked air pressure in both tires making sure they are the same . Then measuring from the floor to the trailer right in front of each fender and at the back of each fender.
Posted: 28 Apr 2019 at 5:33am |
Are your fenders the same height relative to the trailer frame? Put another way, is the 1 inch height difference entirely attributed to the axle or is part of it the placement of the fenders?
tent2pod
Posted: 28 Apr 2019 at 12:04pm |
The fenders appear to be the same height relative to the trailer frame . |
