  New Posts New Posts RSS Feed: Water Pump running
Topic ClosedWater Pump running - Event Date: 22 Mar 2019 - 30 Mar 2019
SC for Huskers View Drop Down
Direct Link To This Post Calendar Event: Water Pump running
    Posted: 22 Mar 2019 at 3:25pm
Picked up Pod from Home Owners A. parking lot to get ready for trip. Plugged in shore power then went in the house.  Came back out an hour later, and heard the water pump runningConfused.  I had forgotten to shut the pump off a few weeks ago when I flushed the sys.  Thought it only runs when calling for water What would cause it to run with all faucets closed?  Last year I had a problem with it not coming on, but that was a broken lug. Sure don't need this now getting ready to go to Cushman Scooter Rally. Thanks in advance Pod'ers.
Happy Traveling,
Tom
2017 172pod
2011 F150 STX
texman View Drop Down
Direct Link To This Post Posted: 22 Mar 2019 at 3:32pm
sounds like it  is sucking air either from the bypass and the antifreeze or from an empty water tank.. put some water in the holding tank and make sure the bypass is closed. it should pressure up then and cut off.
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 22 Mar 2019 at 4:14pm
If it's trying to pressurize the system.. but has no water it will run and run and run..
Direct Link To This Post Posted: 22 Mar 2019 at 4:49pm
Was your battery disconnected? Since the pump runs on 12V and it didn't turn on until you plugged in shore power, if your battery was connected it had probably completely discharged. If so, check to be sure its holding a charge before you head out on your next trip.
Direct Link To This Post Posted: 22 Mar 2019 at 5:56pm
I just checked the Main Battery disconnect switch and it was off.  I turned it on, turned pump switch on and it started running.  I'm still connected to shore power. (Navy Term)  I didn't check voltage on the batteries, but I did keep them charged over the winter and have no reason to think they are bad. I'll put a V meter on them later.
Happy Traveling,
Tom
2017 172pod
2011 F150 STX
Direct Link To This Post Posted: 22 Mar 2019 at 6:11pm
Just put water in the tank (E-1/3) and opened shower cold side and it runs, shut of shower valve and pump keeps running.  I'll unload the cabinet , unscrew the fake wall then eyeball the pump in the morning. Sun is gonging down, Thanks Guys.
Happy Traveling,
Tom
2017 172pod
2011 F150 STX
podwerkz View Drop Down
Direct Link To This Post Posted: 22 Mar 2019 at 11:10pm
If the pump head or one of the tubes or pipes froze during the winter, at or around the pump, it will crack and suck air or pump water, continuously, depending on what broke or split.
Or maybe your antifreeze siphon valve is open.
RockyMtnRPod View Drop Down
Direct Link To This Post Posted: 22 Mar 2019 at 11:11pm
Same thing happened to me last spring. Had a crack in the plastic bowl that holds the small filter just upstream of the water pump. Between the pump and fresh tank.  Was sucking air.  It froze and cracked.
CG
2020 TRD/Off Road Tundra with Sway Bar and SuperSprings
2016 178 "Sage"
Direct Link To This Post Posted: 23 Mar 2019 at 7:44pm
And that is why I use the winterization valve and tube and use the pump to pump RV antifreeze through the system instead of just relying on air pressure to blow out the lines without using RV antifreeze. The RV antifreeze will also protect the pump and strainer bowl as well as the lines.
Direct Link To This Post Posted: 23 Mar 2019 at 8:09pm
And to add to StephenH's comment, that pink stuff is really cheap.  Wallyworld has it in large 2.5 gal. jug for about the same price as a gallon in a most RV stores.  It is a whole lot easier to use the antifreeze than to replace broken plumbing parts.
