Page <1 234 |
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2709 |
![]() Posted: 15 Feb 2019 at 6:49pm |
In the past I have used what used to be called "Duro Extend". The product was picked up by Loctite, and is now called Loctite Extend. What I used it on was metal that was already lightly rusted. The stuff goes on and looks milky white, but as it cures, it will turn the rust black. It acts as a primer for paint. I've also used it on raw steel (before rust).
crw8sr ![]() Senior Member ![]() Joined: 12 Oct 2017 Location: Omaha Nebraska Online Status: Offline Posts: 328 |
We have to deal with salt and other chemicals they put on our winter roads. I wonder if Rustoleum would help.
I think I'd like to tackle this mod.
Do you have pictures of the bar after it was cut and chambered before it was installed? |
Chuck & Lyn
Yes for sure crw8sr, good point.
I live on the OBX so I'm constantly fighting salt corrosion on everything. My thought is to seal the angle to the axle with a flexible adhesive sealant. I want to put a few miles on it first in case there is something that needs to be adjusted or modified. Any other suggestions are welcome.
Any concern about rust between the axle and the steel bar?
Chuck & Lyn
I don’t plan to, when you load the axle the middle will press down into the reinforcement angle, so clamps shouldnt be needed there.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6428 |
Looks great! Will you be putting any clamps in the middle?
This post is a follow on to this topic, which contains a detailed discussion of the issues and load calculations.
GVWR>GAWR and Stabilizer IssuesfeIt applies to the 3500 lb Lippert "diamond" configuration axle only, and will only address stiffening the axle tube itself, and not any failure that might or might not occur in the spindles, torque arms, or rubber components. I had a 77.25 inch long piece of 3x3x3/16 steel angle cut and cambered (crowned) about 3/8 inch in the center. You need to be specific that the crown is made at a 45 degree angle to the angle flanges, pressing on the point or "heel" of the angle. Be sure to measure your axle tube length and allow at least a 0.125 clearance at each end so the torque arm won't rub on the angle ends. The shop I went to specializes in trailer modifications but any shop with the appropriate size hydraulic angle cutter and press should be able to do it. It's not expensive, the fabbed piece cost me $30. I ordered four 1/2 inch square U bolts, shackles, washers, and nuts from these very nice folks: The U bolts need to have a jaw opening of 3.5 inches, I got 6 inch long ones, the shackle, washer and nut stack up is about 1.5 inches but you need some additional length to get things started. There is plenty of clearance under there. The U bolts should go on at 90 degrees to each other, 2 at each end, as close to the ends of the axle as possible while still allowing some clearance to the torque arms. The U bolts and hardware cost around $75. Of course, there is no way to ever "prove" that this reinforcement solves the axle bending problem, but if it is caused by the axle to frame attachments being too far inboard on the rPods, it should help significantly. ![]() ![]() |
Page <1 234 |
