  New Posts New Posts RSS Feed: Door Handle/ Stair Rail question/observation?
Topic ClosedDoor Handle/ Stair Rail question/observation?
Motor7 View Drop Down
Direct Link To This Post Topic: Door Handle/ Stair Rail question/observation?
    Posted: 08 Feb 2019 at 5:07pm
Sorry Furpod...I can't get the link 'reducer' to work.
2016 R-Pod 176T
Direct Link To This Post Posted: 08 Feb 2019 at 5:06pm
I put a marine porthole in the door of our 172.  If worse comes to worse and I can't open the door, I can open the porthole and reach outside and lift the hand rail up making door opening normal.
Did you use this one?
https://www.ebay.com/itm/Round-Opening-Portlight-Porthole-10-Replacement-Hatch-Window-Port-Hole-Boat-RV/123152960434?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
2016 R-Pod 176T
Direct Link To This Post Posted: 08 Feb 2019 at 2:25pm
TheBum View Drop Down
Direct Link To This Post Posted: 08 Feb 2019 at 11:22am
It's easy enough to swap the storage lock positions: just remove a nut on each, pop them out, and then reapply the nuts after the swap.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
tcj View Drop Down
Direct Link To This Post Posted: 08 Feb 2019 at 8:33am
Tearless Tom
I cannot open the door on my 2018 180 if the handrail is closed on top of it.  There was another thread a few months ago about this.  Everyone told me the same as they are telling you and even showing you in a video.
I tried to explain that there must be a different design on the older pods' hand rails but no one seemed to believe that and insist that I am just not pushing hard enough.
P.S.  I did not and am not going to file on the locking mechanism.  I'm a skinny old man but pretty tough and will go out a window if that bad guy locks me in.
2018 R-pod 180 Hood River Edition
Direct Link To This Post Posted: 08 Feb 2019 at 6:56am
TearlessTom View Drop Down
Direct Link To This Post Posted: 07 Feb 2019 at 9:42pm
Originally posted by StephenH
Don't worry about it. It is pretty easy to push the door open and pop the handle away. If you try it and can't do so, a little filing of the edge of the plastic to make a little ramp for the handle will fix that.
As for the storage door, you could reverse it, but the better option is to make sure you lock it before towing. I think it is set up for a right-handed person to be able to use the key easier. If you are left-handed, I guess you could switch them. Then you will have to make sure you turn the finger lock or you will have the same situation.
I am left handed. I guess that is why it bothers me.  I guess it just bothers me in that I have been doing a lot of test drives trying to get my WDH set up correctly.
Good to know you can force the handle open if needed.
Tearless Tom
2017 R-Pod 180
2014 Ford F-150 XLT 2WD 5.0
Direct Link To This Post Posted: 07 Feb 2019 at 9:28pm
+1 on what Stephen said about the handrail. Push the door open "with authority", and it will pop open.
We re-keyed the outside storage door and the outside shower door to use the same key as the entrance door. One key opens them all! I also "adjusted" all the latches so they latch firmly.
Awchief View Drop Down
Direct Link To This Post Posted: 07 Feb 2019 at 9:18pm
Anything could happen. In my 189 I can easily just reach out the window to unblock the door.
Michael
Direct Link To This Post Posted: 07 Feb 2019 at 9:17pm
