  New Posts New Posts RSS Feed: Weight Distribution Welding
Topic ClosedWeight Distribution Welding
texman View Drop Down
Direct Link To This Post Topic: Weight Distribution Welding
    Posted: 16 Jan 2019 at 11:15am
Good points.  no warranty left on Pod, probably some on the hitch.  i wasn't sold on the idea, but didnt really like the way i had to remount my batteryt box because of the bolts.  no big deal and i agree not worth the risk to the a frame and hitch down the road.  Thanks for your input.
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 16 Jan 2019 at 10:28am
I agree with Stephen for a couple of reasons. First, you would never be able to change the hitch, and second, the welding could affect the integrity of the A frame unless done perfectly. Forrest River would never approve this. In fact, the hitch manufacturer would probably not approve either.
Direct Link To This Post Posted: 16 Jan 2019 at 10:13am
There are times and situations where you may need to adjust the brackets. If they are welded, you won't be able to do this. I would not recommend it and I think it would also void any warranty you may have left from Forest River and from Fastway.
Direct Link To This Post Posted: 16 Jan 2019 at 8:46am
Question 1). A TV change shouldn't change the bracket location.
Question 2) The weld itself will be strong but you should spread out the load a little by welding to a sufficient area not to cause a localized high stress in the trailer frame which is only 0.1 inch wall thickness if I recall correctly. A welding professional will know how to make it work.
Direct Link To This Post Posted: 16 Jan 2019 at 8:18am
I have my weight distribution (fastway e2) installed and set where i think is the "sweet" spot.  My question for the group is your thoughts on welding the brackets to the Aframe instead of using the bolts.
I was thinking i could have a pro weld them where they are and then remove the bolts.  I know the welder will have to remove first to prep the area by removing the paint and then reattach and then weld.
Couple of reasons for:  1. I don't have to check the torque of the bolts if welded
2. it frees up some room inside the a frame if the bolts don't protrude into the inside for the battery box to set down in the cavity instead of on top on tubing.
Couple of concerns:  1. will a different tow vehicle require me to move the brackets ?  i don't think so since they are set by distance from the hitch and the weight of the trailer.
2. would welding to the a frame create a spot that is weaker at the weld?  I don't think so because welding usually creates a stronger point because of the fusing of the materials.
Thoughts and concerns?
TexMan 2015 182g
2018 Sequoia
TexManMods
