Page 12> |
JerryCk ![]() Newbie ![]() Joined: 10 Oct 2018 Location: Montana Online Status: Offline Posts: 13 |
![]() Posted: 02 Dec 2018 at 1:07pm |
Is there any way to locate framing members in the walls from inside the trailer?
You can use a stud finder it is somewhat reliable. It is not a frame persay, it is a structure enhanced at critical points like windows and doors. Some advise you look at outside skin to determine aluminum structure, but I have found that is little help on the inside. Do a Google on RPod walls and you will see what I mean about a structure versus a frame. Typical for campers.
Thanks Mike. I've got a stud finder. I'll give it a try. I wonder if there is a continuous strip where the side walls meet the ceiling and floor?
John Lundborg
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Online Posts: 2709 |
There is a complete peripheral aluminum "frame" member (it's relatively small square aluminum tubing). You can see how the frame is built in this Forrest River video. It's a bit dated, as they've replaced the luan plywood with Azdel.
voisj ![]() Senior Member ![]() Joined: 19 Jul 2016 Location: San Luis Obispo Online Status: Offline Posts: 471 |
JerryCk,
Here's an easy way to locate wall studs. A good Quality studfinder should work but you could do this, Warm up the pod to 60 degrees at night, then turn it off,in the morning you should see this. ![]() |
Kevinscamps ![]() Newbie ![]() ![]() Joined: 14 Jul 2018 Location: Fort collins, c Online Status: Offline Posts: 37 |
I had no luck with a stud finder. The thermal camera worked great!!! http://www.rpod-owners.com/forum_posts.asp?TID=12295&PN=1&title=thermal-pictures |
How did you transpose that to the inside?
I've wondered if this device would work:
https://walabot.com/diy# Too bad it only works on Android phones. |
Alan
To locate studs on the inside I used a really good stud finder one that also detects metal and electricity,be aware that the aluminum studs are only a sixteenth of an inch thick and you cannot use a power tool to install it or you will strip the out the aluminum.I ended up drilling a larger hole in the stud and using a plastic anchor.
Thought so, kind of where I was headed 6 posts ago.
Page 12> |
